Re: Thinking About Upping My CI
[Re: MR_P_BODY]
#612569
02/14/10 11:25 AM
02/14/10 11:25 AM
Posts: 16,930 NC
440Jim
NC
I'm thinking of also going to a glide which I have...
Right now its a 3.79 stroke with a 4.125 bore and I turn it in the 8200 range (this is a 405ci)
Although I love my 727, I really think your application would like the PG. They do use less power to drive them, and I don't think the launch is your problem (looking for horsepower, not torque). I think you will see more MPH with the glide.
What cam duration/lift and rocker ratio are you running now? And are you thinking the same duration at 0.050", but a more aggressive lobe profile with more lift?
[Re: 440Jim]
#612573
02/14/10 01:27 PM
02/14/10 01:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Jim, right now its a 276/282 @.050 with 1.6 rockers
[Re: RyanJ]
#612576
02/14/10 08:54 PM
02/14/10 08:54 PM
MR_P_BODY
This is dyno sheet off a 439" W9 (4.0 stroke, 4.185 bore) @ 14:1 with more intake port size than you have (about 2.9" CSA, 286 CC SDSS Hand port), & a very similar bracket cam to what you have now. Off top of my head cam in this motor was 274/280 @ .050" ~.748" lift on 111 in @ 107. Just posted so you can see where it made power RPM wise....
I put same cam in Brian Smith's 417 W8 motor..... (3.79" X 4.185" bore) We did'nt dyno his, but it's been 146 MPH @ over 3100 lbs so.... must make some power. His heads would be similar to yours size/flow wise. ~2.75" CSA
Going to use that cam in a 496" BB GM I am currently working on for local buddy.... Hope to make 850+ with it. It's a good all around 1.7:1 rocker grind for a bracket car.
I doubt you will see much change re-grinding cam in that Chapman head motor. Lift does'nt seem to do a whole lot on the W8/9's.... The Nascar truck W8 stuff was in the .680's & I have ran everything from .660's to .940's & never saw much difference in power. Mid .700's seems to work well & not be hard on parts.
Thanks Ryan.... right now I only have a .688 lift at the valve, thats why I wanted to re-grind it to get at least .750 at the valve.... I guess if I wanted to is just bore it to 4.185 with the same stroke. I also have a back up cam blank for a 48* so I guess I could have it ground
[Re: RyanJ]
#612578
02/15/10 12:05 AM
02/15/10 12:05 AM
MR_P_BODY
That's normally what I shoot for on a W8/9 motor like that, mid .700's, just like dizusters... Does'nt require killer valvetrain & seem to make good power.
Bigger bore would probably help more than the stroke would, & then maybe trick out the new pistons/ring pack if your old stuff was more "mild" & pick up some more HP there...
Thats what I'm thinking also... I believe the small bore is hurting it... shrouds the big valve too much and then the lack of lift
[Re: RyanJ]
#612579
02/15/10 09:15 AM
02/15/10 09:15 AM
Posts: 4,091 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Good revelant info. In the MOROSO HP calculator thread you had a conservatively calculated 610 FWHP. I am sure you have at least 90 HP left in that combination of parts your currently using. That alone will carry your car DEEP into the eights. Is it in the driveline? the tune? That is why I suggested going to dyno. As Ryan mentioned, I doubt you'll find much HP in a regrind. From anything I've seen of the W9's, they don't seem to have the physical integrity to support the valvetrain loads that the W8's will.
[Re: HardcoreB]
#612580
02/15/10 11:46 PM
02/15/10 11:46 PM
MR_P_BODY
Well I think what I'm going to do IF the funds are there is to just bore it and go with the 4.185" pistons and look into a regrind to get it up to .750 lift at the valve.... tune up the heads... if I can come up with the coin I would like to put it on a dyno. The first things I will do when I get home will be to get the car into the shop and do a leak down (when I built it, it was less than 3%) then pull the engine.... hopefully there isnt much snow when I get back home
