Cam help #612505
02/13/10 03:57 PM
02/13/10 03:57 PM
Great White North Werst coast
runya Offline OP
runya  Offline OP
looking for input into a cam selection for my Duster. Would like a solid flat tappet.
75 Duster (3000 lbs)
727 auto with a full manual valve body
5000 stall 8" ptc converter
4:56 gears
28" tires
11.5 compression
410 stroker
2" hooker headers
Holley Pro Dom tunnel ram 2 600 1850's
W2 (2:08 x 1:60 valves minor port work)
roller tip rockers (blue MP ones)
Limited street
Also who is a good company to buy from
Thanks in advance
Russ
Re: Cam help [Re: runya] #612506
02/13/10 09:45 PM
02/13/10 09:45 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Cam help [Re: runya] #612507
02/14/10 01:29 AM
02/14/10 01:29 AM
SoCal
Brian Hafliger Offline
SoCal
4:56 gears
28" tires
11.5 compression
410 stroker
2" hooker headers
Limited street
Thanks in advance
Russ
I'd use this: 260-266 @.050, .578-.551 w/1.5 ratio, on a 107lca and 3° advance.
It's comp lobes.
Brian Hafliger
Re: Cam help [Re: Brian Hafliger] #612508
02/14/10 02:49 PM
02/14/10 02:49 PM
runya Offline OP
runya  Offline OP
Thanks Brian, I bought my existing cam from you a couple years back, this looks like the same one. It worked great but I took a lobe out of it so I need to replace it.
I sent you a email last week but maybe it has changed.
What is the best way to catch up with you for pricing (need new cam and lifters)?
Re: Cam help [Re: runya] #612509
02/14/10 04:14 PM
02/14/10 04:14 PM
SoCal
SoCal
Do you know what may have caused it to lose a lobe??
Brian Hafliger
Re: Cam help [Re: Brian Hafliger] #612510
02/14/10 06:57 PM
02/14/10 06:57 PM
runya Offline OP
runya  Offline OP
I was up on the rev limiter (7000rpm) and it started to pop so I shut it down. When I pulled the valve cover I had one push rod off the rocker cup wedged between the rocker and the head. The only thing I can see is a combination of the clearance set a little to loose, possible valve float with the agressive lobes.
Cam was working great up to that point.
