Holley carb ID# 80470 #612257
02/13/10 09:12 AM
02/13/10 09:12 AM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
Seems to be the only # on the air horn 80470 with 0813 under that. Its a spreadbore with 2 wires comming out of the top of the front bowl. Anybody know. Can't seem to find it on the Holley site.
Re: Holley carb ID# 80470 [Re: Russ_Davis] #612258
02/13/10 09:56 AM
02/13/10 09:56 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
A quick search on the world wide web returned this:
http://www.collectorcarsforsale.com/part...0486259709.html
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Holley carb ID# 80470 [Re: runinonmt] #612259
02/13/10 10:04 AM
02/13/10 10:04 AM
Pittsfield, Mass.
Pittsfield, Mass.
Thanks I know that I bought it. Just looking for what it is and any cut sheets on it.
Re: Holley carb ID# 80470 [Re: Russ_Davis] #612260
02/13/10 02:53 PM
02/13/10 02:53 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Try the Holley web site.
Re: Holley carb ID# 80470 [Re: Lee446] #612261
02/13/10 03:47 PM
02/13/10 03:47 PM
Pittsfield, Mass.
Pittsfield, Mass.
I can't find it listed, thats why I'm asking here.
Re: Holley carb ID# 80470 [Re: runinonmt] #612262
02/13/10 05:42 PM
02/13/10 05:42 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
[url=http://www.collectorcarsforsale.com/parts/HOLLEY-carb-carburetor-650-cfm-MOPAR-dodge-chrysler-For-Sale_110486259709.html]
What the helll is that!!!! Enlighten this old man.
Re: Holley carb ID# 80470 [Re: Commando1] #612263
02/14/10 10:10 AM
02/14/10 10:10 AM
Pittsfield, Mass.
Pittsfield, Mass.
Anyone else figure what this carb is??????????
Re: Holley carb ID# 80470 [Re: Russ_Davis] #612264
02/14/10 11:45 AM
02/14/10 11:45 AM
scratchnfotraction Offline
got a pic of it?
I got a spred bore holley that is a 650cfm and a double pumper with vac choke pull off
no wires???
a replacement for a thrmobog/q-jet feed back carb maybe???
wires on carbs
Re: Holley carb ID# 80470 with pics [Re: scratchnfotraction] #612265
02/14/10 04:46 PM
02/14/10 04:46 PM
Pittsfield, Mass.
Pittsfield, Mass.
heres one
Re: Holley carb ID# 80470 with pics [Re: Russ_Davis] #612266
02/14/10 04:47 PM
02/14/10 04:47 PM
Pittsfield, Mass.
Pittsfield, Mass.
Another
Re: Holley carb ID# 80470 with pics [Re: Russ_Davis] #612267
02/14/10 06:54 PM
02/14/10 06:54 PM
Commando1 Offline
Commando1  Offline
Those pics are simply from the eBay listing.
It's not answering the question.
W T F is it?
Re: Holley carb ID# 80470 with pics [Re: Commando1] #612268
02/14/10 07:00 PM
02/14/10 07:00 PM
Pittsfield, Mass.
Pittsfield, Mass.
I know there from the listing I bought it.. Now I need bowl gaskets and there bigger than the 108 series
Re: Holley carb ID# 80470 with pics [Re: Russ_Davis] #612269
02/14/10 07:48 PM
02/14/10 07:48 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Man, I am trying to drag it out of my memory, but I think it was from the early eighties and Holley came out with it as a 650 that could be adjusted while driving to obtain as lean a mixture as possible and boost mileage. You would have to call Holley to verify though.
Re: Holley carb ID# 80470 with pics [Re: Lee446] #612270
02/14/10 09:17 PM
02/14/10 09:17 PM
oh! thats just a holley gas hole
yep,air/fuel ratio on the fly
wires in the carb
Re: Holley carb ID# 80470 with pics [Re: Russ_Davis] #612271
02/15/10 10:04 AM
02/15/10 10:04 AM
Commando1 Offline
Commando1  Offline
Oops, sorry. I didn't notice you were the OP. so let me redeem myself.
I found this from another forum:
I've been using those for about 7yrs now on a daily driver and they work geat. Very easy to tune. I also used the there CircleTrack blocks on a race engine and I loved not having to drain the bowls everytime i changed jets at the track. I think they have Drag blocks also. There different colors and can flow more than the stock AdjustaJets.
Holley made something similar to this a good while back. There's had an electric motor on the adjustable jet and you could tune them while driving from inside the car. I think it had a Air/Fuel meter too. Saw some on Ebay a few years ago.
They were talking about the Holley Adust-A-Jet.
Apparently it's one of regular models with an Adjust-a-jet kit and in this case it was an early type that was motorized.
Not much but it's a tiny bit more...
Re: Holley carb ID# 80470 with pics [Re: Commando1] #612272
02/15/10 03:53 PM
02/15/10 03:53 PM
good save!
Re: Holley carb ID# 80470 with pics [Re: scratchnfotraction] #612273
02/15/10 06:14 PM
02/15/10 06:14 PM
Commando1 Offline
Commando1  Offline
good save!
I'm only a complete A-hole some of the time.
Re: Holley carb ID# 80470 with pics [Re: Commando1] #612274
02/15/10 06:19 PM
02/15/10 06:19 PM
not in my book,I must not got to that chaptor yet
Re: Holley carb ID# 80470 [Re: Russ_Davis] #612275
02/16/10 06:37 PM
02/16/10 06:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Everything you need to know.
