error codes on 2007 Chrysler mini van #610444
02/11/10 10:43 AM
02/11/10 10:43 AM
Tennessee
HOOVER24K Offline OP
super street
super street
Tennessee
How do you pull up the error codes on a 2007 Chrysler mini-van. The check engine light came on and would like to know what the cause is. Thanks
[image]http://s18.photobucket.com/albums/b148/hoover24k/?action=view¤t=web_IMG_0515.jpg[image]
Re: error codes on 2007 Chrysler mini van [Re: HOOVER24K] #610445
02/11/10 01:29 PM
02/11/10 01:29 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
They have to be read with a code reader or scan tool.
If you have an Autozone close most will read them for free. at least around here anyway.
Re: error codes on 2007 Chrysler mini van [Re: HOOVER24K] #610446
02/11/10 06:09 PM
02/11/10 06:09 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
Not sure if it will work, but you can try the rapid key on/off/on/off/on and the codes may appear in the odometer readout.
Try it!
Re: error codes on 2007 Chrysler mini van [Re: DartGTDan] #610447
02/12/10 01:11 AM
02/12/10 01:11 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Try it!
This will still work. Be ready to write down numbers, all of them will be two digits. An assistant can be helpfull as you count and holler out a number they write it down.
What will happen is a you will see the CEL flash between 1 and 9 times then a quick pause and the same thing, then there will be a noticably longer pause and it will flash the next two digit code the same way it flashed the firs code. Write them all down and report back to us what you find.
