Re: Drilling/installing '71 Gull Wing Help Needed
[Re: VITC_GTX]
#610130
02/13/10 12:37 AM
02/13/10 12:37 AM
Posts: 17,554 Las Vegas, NV
6bblgt
Las Vegas, NV
Yes, there is space between the exterior sheetmetal and the brackets. pic stolen from the other wing thread '70 'Cuda wing
[Re: DAYCLONA]
#610140
02/21/10 01:50 PM
02/21/10 01:50 PM
Posts: 1,547 Puyallup, Wa.
Steve340
Puyallup, Wa.
I posted the factory print(on another post), the one Steve has, I don't know were that came from,...but the required holes are .281 or 9/32",....I wouldn't exceed 5/16" (.312) diameter
Mike
Wow. I never noticed that before on the hole size. That sheet came with some NOS brackets and hardware for the A-body. It was folded up in the box.
[Re: 6bblgt]
#610141
02/21/10 02:06 PM
02/21/10 02:06 PM
Posts: 4,966 Tri-Cities, Washington
VITC_GTX
The factory engineering drawing posted above appears to have 4 holes at .281" (9/32") diameter.
Thanks. I couldn't read the numbers on the sheet you posted, it was too small and I couldn't figure out how to enlarge.
[Re: DAYCLONA]
#610142
02/21/10 02:09 PM
02/21/10 02:09 PM
VITC_GTX
Mike
Well, unfortunately I went 7/16" on the holes. Once the wing is in place the holes are covered and the provided nuts are centered well enough to cover the holes from underneath.
I don't see any reason to weld them up or get another trunk lid. This is just going to be a fun car anyway.
Lesson learned I guess.
