How to proportion my brakes???? #609761
02/10/10 03:31 PM
02/10/10 03:31 PM
oregon
ramcharger1964 Offline OP
oregon
Need some advice on how to properly proportion my braking system. Have SSBC discs in front and OEM type discs on the rear with a SSBC proportioning valve. What's the best way toset it up. It is basically a strip/street car but much more on the strip side.
Hell B!tch Racing Co.
Re: How to proportion my brakes???? [Re: ramcharger1964] #609762
02/10/10 04:11 PM
02/10/10 04:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On a open straight road try locking up the brakes,
adjust so they all do at the same time... be careful
not to flat spot the tires
Re: How to proportion my brakes???? [Re: ramcharger1964] #609763
02/10/10 04:12 PM
02/10/10 04:12 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Try this. When you set the bias make sure you do it on a flat smooth surface. I usually use parking lots.
http://robrobinette.com/brake_valve.htm
