Rocker arm spacers? #609509
02/10/10 11:59 AM
02/10/10 11:59 AM
Westphalia, Meeeeeshigan
MIRADAMANia Offline OP
I put Mopar Performance replacement rockers on my 346 heads and they seem to be able to slide sideways off the valve tips. Do they need some kind of shim or spacer between each rocker? The spacers that go under the bolts are there.
Re: Rocker arm spacers? [Re: MIRADAMANia] #609510
02/10/10 12:03 PM
02/10/10 12:03 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Big blocks DO use spacers between each 2 rockers of a cylinder. Kind of fat ones too.
Re: Rocker arm spacers? [Re: MIRADAMANia] #609511
02/10/10 12:05 PM
02/10/10 12:05 PM
michigan woods
imfixinmopars426 Offline
michigan woods
ring in between rockers,and make sure the rockers are pointing in the correct direction..[L-R] also...center bolt is long,and has the wider hold down support.
Re: Rocker arm spacers? [Re: imfixinmopars426] #609512
02/10/10 12:33 PM
02/10/10 12:33 PM
Beautiful. Thanks for the quick answers!
