Diesel Ram issues
#609486
02/10/10 11:18 AM
02/10/10 11:18 AM
Posts: 18,263 Charlotte, NC
Orange_Crush
Belieber!
Belieber!
Charlotte, NC
Last week, I asked about issues with my Ram. It was throwing a code (P2146). Shortly after that happened, the ram started idling VERY roughly and lost a considerable amount of power. I had it towed to the dealership where the harness for the 1,2,and 3 injectors was replaced. After I picked it up and drove it for about 20 minutes, the exact problem started again.
It appears that this is a problem that only occurs after the truck is warmed up. it has a new harness on it, so what could it be? Could it be an injector issue? Lift pump? The truck is a 2005 Ram 3500 auto. The tech seems to believe an injector is failing once the truck gets warm, but he will have to drive the truck for a while to replicate the issue so he can then test for the problem. What do you guys think?
1970 Dodge Charger R/T Hemi Orange U-code 4-speed 1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
Re: Diesel Ram issues
[Re: 727jim]
#609489
02/10/10 01:25 PM
02/10/10 01:25 PM
Orange_Crush
Belieber!
Belieber!
Charlotte, NC
2005.
Its not stalling, just suddenly idling very rough and losing power. when the truck cools down, everything works fine until its warm again.
I don't have a scan tool to monitor fuel pressure so I can't tell you.
The OBD scanner threw P2146 which is: Bank one-cylinders 123 short circuit high or low.
The harness was replaced as it is a fairly common problem, but issue persists.
[Re: Orange_Crush]
#609490
02/10/10 03:01 PM
02/10/10 03:01 PM
Posts: 6,516 Santa Cruz, California
Lefty
That indicates the problem is further back from the new harness or there is an injector problem.
The 1st thing that should have been checked is the lift pump pressure when the truck starts running rough.
I would not trust the tech who threw a harness at the problem without any testing and did not drive the truck to make sure he had fixed the problem correctly. I certainly would not pay for the harness or labor.
They/you need to look at the signals to the injectors when the problem is occurring. If the signals look like the cylinders 4,5,6 signals, the problem is most likely an injector.
A heat gun is a valuable tool for finding heat related problems. Preheat the lift pump when the truck is cold and keep heating for a few minutes while running. You can do the same for components previous to the new harness.
You can swap injectors one at a time from 4,5 or 6 to see if the problem moves or buy/borrow one good injector and move it from 1 to 2 to 3 and see if the problem goes away.
[Re: Lefty]
#609491
02/10/10 03:28 PM
02/10/10 03:28 PM
Orange_Crush
Belieber!
Belieber!
Charlotte, NC
Wow...wasnt expecting THAT much info Fortunately, the engine is still under the cummins warranty (5 years 100,000 miles) so this was a good time for this to happen if it was going to. Unfortuantely, I am kinda suspicious of the guy who throws the harness at it too. Especially when he told me that is what he did (his words "The harness is a faily common problem so I replaced yours."). Unfortuantely, Cummins Atlantic won't work on post-2003 Dodge trucks so I am left with the Dodge dealerships around here, neither of which have a very good reputation. I mean, the tech seemed pretty knowledgeable, but it bothers me that he didnt go more in-depth about it.
[Re: Rhinodart]
#609496
02/10/10 10:17 PM
02/10/10 10:17 PM
Orange_Crush
Belieber!
Belieber!
Charlotte, NC
Craig, I had an injector go wide open, pour raw fuel in a cylinder, and hydrauliced the motor causing it to throw a rod! Injector problems are nothing to be casual about...
Jim, when it happened, the first thing I thought of was what happened to you, so as soon as it happened, I stopped the truck and called a tow truck.
It turns out it was a bad injector, the parts dept. is waiting for a new one and they should get it tomorrow.
