Lifting Points 5.7 Hemi??? #609406
02/10/10 07:36 AM
02/10/10 07:36 AM
Rome, Ga
sbhpcb Offline OP
sbhpcb  Offline OP
Rome, Ga
Where are you attaching the chains to on the 5.7 Hemi in order to lift with the Hoist?
Re: Lifting Points 5.7 Hemi??? [Re: sbhpcb] #609407
02/10/10 06:59 PM
02/10/10 06:59 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
i installed my 6.1 (motor only) using for metric bolts attached to the heads, i believe factory has a gadget that grabs intake somehow.
I had four bolts, they were towards top nearest intake front and back
Re: Lifting Points 5.7 Hemi??? [Re: sbhpcb] #609408
02/10/10 10:34 PM
02/10/10 10:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
There is a stud sticking out of the front top of the timing cover that's intended to be used as a lift lug. I use that along with two other attaching points near the back of the engine, take your pick of any two that look strong enough, get some long bolts and thread them in all the way.
Rich H.
Esse Quam Videri
