Predator horsepower #609168
02/09/10 09:27 PM
02/09/10 09:27 PM
virginia
572stealth Offline OP
virginia
I'm getting ready to build a Predator motor for a customer and I'm looking for some real world power numbers. The motor is 592", Ken spec'ed a cam of .929"In .875"exh with 283/308. Also looking for recommendations on header sizes.
Re: Predator horsepower [Re: 572stealth] #609169
02/09/10 09:40 PM
02/09/10 09:40 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Elvis has left the building.
Re: Predator horsepower [Re: 572stealth] #609170
02/09/10 09:42 PM
02/09/10 09:42 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
sorry. a former Moparts member had Predators, think he hangs out at Yellowbullet.com now.
Re: Predator horsepower [Re: forphorty] #609171
02/09/10 09:49 PM
02/09/10 09:49 PM
virginia
virginia
Don't step on my blue suede shoes.
Re: Predator horsepower [Re: 572stealth] #609172
02/09/10 11:01 PM
02/09/10 11:01 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Mine as well as others on this board were up and running waaaaaaaaay before elvis!!
Mine 572" cam way bigger than the one you posted, with a 2 1/2 " primary (24"long)and a 4 1/2" merged collector made 1231 hp and 865 lb. tq.
Re: Predator horsepower [Re: boatracer572] #609173
02/09/10 11:13 PM
02/09/10 11:13 PM
Dyno1 Offline
Dyno1  Offline
A friend of mine built a 572 and made in the 1200 HP range.
Post deleted by Defbob [Re: forphorty] #609174
02/09/10 11:27 PM
02/09/10 11:27 PM
Re: Predator horsepower #609175
02/10/10 12:23 AM
02/10/10 12:23 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Wheatcraft's dragster is a 640 I believe and makes over 1300 HP and makes over 1100 at 4000 rpm.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Predator horsepower [Re: Irun5snd8th] #609176
02/10/10 12:41 AM
02/10/10 12:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What about Wheatcrafts Neon, If I recall it has Predator power to..Someday I will have a car worthy of Predator Power. I woudl think with a 598 1200 is a no brainer, so to speak. If my little B1 can make 1050 then you shoudl be there easy.
Re: Predator horsepower [Re: Al_Alguire] #609177
02/10/10 12:53 AM
02/10/10 12:53 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Chris still has the Neon as well and it is also Predator powered. That thing is over 1200 and seems to be easier on parts than the motor in the digger but I believe there is about a 100 hp difference between the two engines. Nevertheless most of these engines are 1100+ HP
Re: Predator horsepower [Re: Irun5snd8th] #609178
02/10/10 01:33 AM
02/10/10 01:33 AM
Renton Washington
Triple Threat Offline
Renton Washington
I wouldn't mind owning that car
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Predator horsepower [Re: Triple Threat] #609179
02/10/10 01:36 AM
02/10/10 01:36 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Go greens car has enough power to go 203 on 10.5's.. Don't know what it weighs, but it makes a buttload of power.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Predator horsepower [Re: 572stealth] #609180
02/10/10 02:02 AM
02/10/10 02:02 AM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
What manifold?cast t/r or sheetmetal t/r?
That cam should be OK albiet a little short on lift and int duration.
2-1/4 2-3/8 2-1/2 into a 4.5" collector approx 13" long
My estimate is 1275hp
Let us know how you make out!
Re: Predator horsepower [Re: 572stealth] #609181
02/10/10 05:19 AM
02/10/10 05:19 AM
iowa
wesw Offline
wesw  Offline
iowa
my 588 predator is a little over 1200 hp with out the nos. it's set up with two systems on it.
598 ci predator
Re: Predator horsepower [Re: gillman34] #609182
02/10/10 07:30 AM
02/10/10 07:30 AM
virginia
virginia
He's got the cast T/R w/two Prosystems. Car is a Daytona weighing 2250 w/driver & a glide. What kind of et's are you all getting with your motors and what kind of breakage have you all experienced?
Re: Predator horsepower [Re: Irun5snd8th] #609183
02/10/10 11:44 AM
02/10/10 11:44 AM
oh
julian2007 Offline
julian2007  Offline
oh
I think the neon is a 604 and it is for sale on rj herd he is going bigger.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Predator horsepower [Re: forphorty] #609184
02/10/10 11:59 AM
02/10/10 11:59 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Wether you like Elvis or not the reason people associate him with preadator motors is because he told us and showed us everything he knew about them, gave us real nice tech info. I have not seen any other serious info from any of the other guys running/building them... hint hint
Re: Predator horsepower [Re: HotRodDave] #609185
02/10/10 12:13 PM
02/10/10 12:13 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I have to disagree. BoatRacer572 among others have been forthright and helpful all along on here with Predator advise. Because people don't necessarily publish or chronicle everything they've done doesn't mean they aren't a helpful resource...don't scare them away. Some people just have so big an ego (IMO) they have to broadcast everything they do. Or they are doing it to corral potential customers.
Re: Predator horsepower [Re: HotRodDave] #609186
02/10/10 12:17 PM
02/10/10 12:17 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Elvis...told us and showed us everything he knew about them
Like camshaft, piston, and intake manifold particulars? NO he hasn't.
Re: Predator horsepower [Re: HardcoreB] #609187
02/10/10 01:23 PM
02/10/10 01:23 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I am really happy with them .
I did do a bunch of welding on mine and the castings are pretty good .( I now have 19 head bolts )
I have 1/2 pushrods , so I had your usual sand drift of aluminum around the engine stand for clearancing .
The 1.9 rockers ,and 1/2 pushrods the only lifter that would clear was the jesel. A friend of mine is going to try the Jesel dogbone style lifter on his build. Those have the pushrod receiver cup located far down in the lifter body, I think he will have problems with the pushrod hitting the lifter body because of the exit angle . We will soon find out.
Next block will definitely be 2" lifter bore spacing with a 60mm cam tunnel.
Between 1200 to 1300 HP for these engine in full race trim is commen I believe.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
