Re: advice on a new knocking sound please
[Re: dirtybee]
#609120
02/09/10 08:35 PM
02/09/10 08:35 PM
Posts: 58 laurens,south carolina
mopar_rr
pull the oil filter thats what i did aweek ago.i had same problem,oil filter had matel in it..cut it open...
HAVE A NICE MOPARIN DAY....
[Re: mopar_rr]
#609121
02/09/10 10:00 PM
02/09/10 10:00 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Lot's of possibilities. Spun a bearing, wiped a cam lobe, who knows. If I need to start mine to move it in the winter, I heat the garage first, so that it get's good oil flow immediately. Really no need to start it, unless you plan on driving it. Starting it monthly has no benefits of any kind to health of the motor For winter storage, put it in the garage, disconnect the battery, and leave it there till spring. Start it up in the spring, warm it up good, and change the oil. All moot at this point. Pull the valve cover on the side you heard the noise. Check for rockers that have a bunch of play. That will tell if you wiped the cam or not. If you do suspect a rod, you could start it, and pull the plug wires, to see which hole it is(doesn't always work, but sometimes) Also, a rod bearing typically gets worse under load. So if you hear the knock, put it in gear, and see if gets louder. In contrast, A main bearing get's worse with higher speeds. Rev it up unloaded. If it get's worse, it's likely(not for sure) a main bearing. Doing these checks with an oil pressure gauge installed, is very informative also. No pressure, likely no bearings left. Time for an overhaul.
[Re: dirtybee]
#609123
02/10/10 09:14 AM
02/10/10 09:14 AM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Define "Warmed up at idle" ![](/ubbthreads/images/graemlins/shruggy.gif) How long running? Piston slap is a longshot, I know... My 2000 Ford 330ci with 217K on it sounds brutal each morning after starting in the winter cold after running about a minute the Piston slap becomes brutal, then disappears after 4 mins and purrs.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: dirtybee]
#609127
02/11/10 09:39 AM
02/11/10 09:39 AM
Posts: 7,506 Az
Crizila
Az
Don't immediately go to the worse case scenerio. Not likely you spun a rod bearing or wiped a cam lobe, especially if the motor had some time on it. My first guess would be a lifter not pumping up. Starting it in the dead of winter won't hurt it. People did it all the time in the 60's and 70's ( they had winters back then too ) to go to work and didn't have major engine failures. Don't go tearing things apart until you do a little diagnosing. I'd fire it back up with a decent oil pressure guage on it and if the pressure is good ( not too high or low ), I'd let it run for a while. If it is a lifter, it will usually puimp back up in time.
Fastest 300
[Re: dirtybee]
#609128
02/11/10 10:23 AM
02/11/10 10:23 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
it's winter so i fire up the bee about once a month or two in the unheated garage. as the old 440 warmed up at idle i started noticing a knocking sound that seemed to be coming from the drivers side block (this was from inside the car). it was getting louder by the minute so i freaked and just shut it off. never blown a motor before and don't really want to. no load, cold temps, and no revving. could i have spun a rod bearing? what would you do? thanks in advance. dave
Hi, Dave. I remember part of your combination. Can't remember what heads you are using. The first things to check are the basics. Like mentioned check for loose bolts (converter, header, etc.).
Chances are, one of the header bolts came loose. If you have eddy heads, that will sound much different than an iron head. It takes a good ear to differentiate that sound from something deeper in the engine. I know this has happened to me when I had to start me car through the Canadian winters. Have faith, it's something as simple as this.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: Crizila]
#609129
02/11/10 12:16 PM
02/11/10 12:16 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
They sure did. But in most cases they ran long enough to completely warm the system, including the transmission and long enough to evaporate a lot of the condensation out of the system. They aslos changed oil very frequently in the winter. None of the 2-3000 mile or farther oil changes. A lot of them changed at 500 miles in the winter.
