72 swing horn/ingniton wiring problem #608797
02/09/10 02:20 PM
02/09/10 02:20 PM
Alberta Canada
wremote Offline OP
wremote  Offline OP
Alberta Canada
I am finally hooking up the wiring on my 72 Swinger.
I have a strange problem!!
When I activate the horn button the horn relay clicks but the horns don't work. (if I supply 12V directly to the horns they work)
When I turn the ignition switch to start the horn comes on!!
I have checked the 72 dodge wiring diagrams and surprisingly this seems to be the way it is wired.
If I trace the wiring back from the horns to the bulkhead connector they actually match up with the ignition wire!! (both physically and per the wiring diagram)
If I trace the horn wire from the horn relay it ends up going to the starter relay (both physically and per the wiring diagram)
I am attaching the wiring diagrams I am using.
Any help would be greatly appreciated
72 Swinger not numbers matching but 97% MOPAR
Re: 72 swing wiring diagram part a [Re: wremote] #608798
02/09/10 02:23 PM
02/09/10 02:23 PM
Alberta Canada
wremote Offline OP
wremote  Offline OP
Alberta Canada
Here is part A of the Dart wiring diagram
