Re: BB HP Exhaust manifold heat riser question...
[Re: Scatransit]
#608723
02/09/10 11:24 AM
02/09/10 11:24 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
2899879 is for 70-71 383 Hp and 440 Hp applications. 2843992 is 383 lp, 383 hp & 440 Hp applications 68-69.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#608724
02/09/10 11:34 AM
02/09/10 11:34 AM
RapidRobert
70GTX440Dana do the later (71 up) BB HP ex manifolds flow as good as the much sought after gold standard 68-70 ones?
[Re: 70gtx440dana]
#608726
02/09/10 12:56 PM
02/09/10 12:56 PM
RapidRobert
Thank you. yeah if the outlet is the same dia and the general shape the same then w the wall thickness in all likely hood being the same then they should flow prett darn close.
[Re: RapidRobert]
#608727
02/09/10 03:57 PM
02/09/10 03:57 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
Can I steal this thread for moment with this question: Is there a separate exhaust maifold # for 67 383 4bbl, I have 67 383 2bbl 2532625 & 2532459 and looking at GG white book, they appear the same?..thanks
Semper Fi
