New piston question???
#608284
02/08/10 09:52 PM
02/08/10 09:52 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I have a new set of Ross dome pistons .030 440. They have a "ridge" between the valve reliefs. I hope you cansee it in this picture. Q: Do I need to remove this ridge? What about the other "sharp" edges on the dome and around the plug relief? Should they be masseged or run as is? I just realized that in 20 some years of racing, this is the FIRST set of NEW pistons that I'VE ever had! Always bought someone else's hand-me-downs.
Re: New piston question???
[Re: Cab_Burge]
#608288
02/08/10 10:14 PM
02/08/10 10:14 PM
'72CudaRacer
Mooresburg, Tn
I try not to run any sharp angles in the comustion chamber, take the sharp edge off with a small knife, don't take a bunch off, just round the edge off so it won't cut you or feel sharp
I was thinking That I'd use very fine sand paper to just "knock off" the edge. Any thoughts about that?
[Re: 9secondsatellite]
#608289
02/08/10 10:17 PM
02/08/10 10:17 PM
'72CudaRacer
Mooresburg, Tn
they haven't been balanced yet i take it. are you going to coat them? i would round out the edges but nothing radical. don't need to remove the ridge but just smooth it with some very fine stuff.
No, not balanced yet. Planing to do that sat. Coat them with what?
#608291
02/08/10 10:32 PM
02/08/10 10:32 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Yep Nock the sharp edges down how ever you can.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
#608293
02/08/10 11:52 PM
02/08/10 11:52 PM
Posts: 1,031 South Jersey
kruger
Yours Too!
Yours Too!
South Jersey
I have those same pistons.Just take a dremmel with a fine roll and just radius the sharp edges around the dome.Then polish them up.
As stated above,nothing radical.Just imagine making a sharp right turn at a lite.
