Pulling 833 4spd tonight , any tips? #607869
02/08/10 12:52 PM
02/08/10 12:52 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I'm helping a friend pull a 833 out of his 72 Dart tonight any tips?? I've never pulled a manual before,just the auto.
Re: Pulling 833 4spd tonight , any tips? [Re: 74RR] #607870
02/08/10 12:59 PM
02/08/10 12:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It's a lot easier. Drive shaft, crossmember, linkage, speedo cable and four bolts holding the tranny to the bell housing. After removing the driveshaft tie wrap a sandwich bag over the trans tailshaft housing to keep from losing the lobe
Re: Pulling 833 4spd tonight , any tips? [Re: stumpy] #607871
02/08/10 01:10 PM
02/08/10 01:10 PM
74RR Offline OP
74RR  Offline OP
Thank you!!
Re: Pulling 833 4spd tonight , any tips? [Re: 74RR] #607872
02/08/10 01:16 PM
02/08/10 01:16 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
If you have a spare slip yoke that works best. Also if it is a small block take the dist cap loose so when the engine hangs down it doesn't break it against the firewall. Ask me how I know.....
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Pulling 833 4spd tonight , any tips? [Re: 64dodge572] #607873
02/08/10 04:22 PM
02/08/10 04:22 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
That and make sure you both ate your Cheerios.I usually leave my floor jack under the trans till its all loose.I also put another one under my oil pan with a block of wood between it.Then I get my sons to help me get it in and out.I used to just set it on my chest and do it.But Im getting old and need help now.Rocky
Chrysler Firepower
Re: Pulling 833 4spd tonight , any tips? [Re: 64dodge572] #607874
02/08/10 04:25 PM
02/08/10 04:25 PM
get a pair of long bolts the same dia as your (4) trans to bell bolts, cut the heads off, cut a screwdriver slot in one end (of each one) then take out the 2 top bolts and replace them w your new ones then remove the bottom bolts and the trans will slide back/out wo damaging the clutch wo you having to muscle it near as much to hold it up till it clears.
Re: Pulling 833 4spd tonight , any tips? [Re: RapidRobert] #607875
02/08/10 04:30 PM
02/08/10 04:30 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Yep, and take the fan blade off the front of the engine. You will have to tip the end of the trans down which could drive your fan blades into the radiator if they are close. I usually remove the shroud, blade and clutch. I use threaded rod with a couple of nuts out on the end so I can have a stop for the trans to hit. I double nut them to install the rods.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Pulling 833 4spd tonight , any tips? [Re: 74RR] #607876
02/08/10 05:08 PM
02/08/10 05:08 PM
Minnesota USA
Dart6pak Offline
Dart6pak  Offline
Minnesota USA
This is Rick in Eden Prairie
If you want to give me a call at 952-829-7386 I can give you the step by step removal process.
Re: Pulling 833 4spd tonight , any tips? [Re: Dart6pak] #607877
02/08/10 10:03 PM
02/08/10 10:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Listen to The Rock, I used to bench press them in and out, but not so much anymore. Getting a bit too old for that and my son is only 4, so no help there and my daughters are all sphaghetti armed.
Whatever you do, don;t try to catch it if it starts to fall off the jack, you will break something, of yours not the trans.
Don't be the exception.
Re: Pulling 833 4spd tonight , any tips? [Re: Supercuda] #607878
02/09/10 11:23 AM
02/09/10 11:23 AM
Niles , Ohio
Niles , Ohio
If you do try to set it on your chest to install pull the drain plug.That thing will dig into your chest bad.I forgot about the long bolts.It makes it easier to get it in position.Make sure if you are replacing the clutch to have the flywheel resurfaced and use a spline tool to align it.Rocky
Chrysler Firepower
Re: Pulling 833 4spd tonight , any tips? [Re: 74RR] #607879
02/09/10 11:42 AM
02/09/10 11:42 AM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
You have it pulled now, right? No problems I hope. And you did not get smashed by that chunk.
Wonder (since I have mine out of the car too) WHY you pulled it. Problems with 2nd gear???
After all these years having a 440 I realized that this means having an attitude... and a budget.
