Re: Pulling 833 4spd tonight , any tips?
[Re: 74RR]
#607872
02/08/10 01:16 PM
02/08/10 01:16 PM
Posts: 4,285 Ohio
64dodge572
Ohio
If you have a spare slip yoke that works best. Also if it is a small block take the dist cap loose so when the engine hangs down it doesn't break it against the firewall. Ask me how I know..... Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#607873
02/08/10 04:22 PM
02/08/10 04:22 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
That and make sure you both ate your Cheerios.I usually leave my floor jack under the trans till its all loose.I also put another one under my oil pan with a block of wood between it.Then I get my sons to help me get it in and out.I used to just set it on my chest and do it.But Im getting old and need help now.Rocky
Chrysler Firepower
[Re: 64dodge572]
#607874
02/08/10 04:25 PM
02/08/10 04:25 PM
RapidRobert
get a pair of long bolts the same dia as your (4) trans to bell bolts, cut the heads off, cut a screwdriver slot in one end (of each one) then take out the 2 top bolts and replace them w your new ones then remove the bottom bolts and the trans will slide back/out wo damaging the clutch wo you having to muscle it near as much to hold it up till it clears.
[Re: Dart6pak]
#607877
02/08/10 10:03 PM
02/08/10 10:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Listen to The Rock, I used to bench press them in and out, but not so much anymore. Getting a bit too old for that and my son is only 4, so no help there and my daughters are all sphaghetti armed.
Whatever you do, don;t try to catch it if it starts to fall off the jack, you will break something, of yours not the trans.
[Re: Supercuda]
#607878
02/09/10 11:23 AM
02/09/10 11:23 AM
therocks
Niles , Ohio
If you do try to set it on your chest to install pull the drain plug.That thing will dig into your chest bad.I forgot about the long bolts.It makes it easier to get it in position.Make sure if you are replacing the clutch to have the flywheel resurfaced and use a spline tool to align it.Rocky
Chrysler Firepower
[Re: 74RR]
#607879
02/09/10 11:42 AM
02/09/10 11:42 AM
Posts: 263 Switzerland, Europe
Swiss_Robert
Switzerland, Europe
You have it pulled now, right? No problems I hope. And you did not get smashed by that chunk.
Wonder (since I have mine out of the car too) WHY you pulled it. Problems with 2nd gear???
After all these years having a 440 I realized that this means having an attitude... and a budget.
