Re: Eddy Heads and Doug's headers question
[Re: Garranimal]
#607744
02/08/10 12:02 PM
02/08/10 12:02 PM
Posts: 660 East Lansing, Michigan
OldHippie
super gas
super gas
The issue with the Doug's, and many others, is the one size fits all big block header design. They would just fine on a 440 block since the taller deck height places the header away from the transmission a bit. Are you using a deep pan? I had this issue a couple of times and cured it with a standard depth pan. TTI's are specific for B and RB applications. I know, $$$$$$$$.
The Old Hippie Hisself
[Re: Stanton]
#607748
02/08/10 05:28 PM
02/08/10 05:28 PM
Dougs has 151 and 152 part numbers--one for 440 and one for lo deck--and its that #6 spark plug that is going to be the problem
[Re: OldHippie]
#607749
02/08/10 06:36 PM
02/08/10 06:36 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
So are the Doug's !!!
[Re: ]
#607750
02/08/10 07:27 PM
02/08/10 07:27 PM
Posts: 128 Tampa, FL
Garranimal
Tampa, FL
http://www.pertronix.com/catalogs/pdf/dougs/2010/dougs_2010.pdf (page 9) above is the link to the headers (D451). I appreciate everyone's input so far, but has anyone ever used spacers? I have spoken to the techs at Dougs and the advice i got was to use as big a prybar as possible (??!!). I don't even know what that means exactly. I have fixed the problem with the starter, but i have no clue as to what to do with the passenger side header hitting the tranny? My fear is boiling the tranny fluid through heat transfer.
[Re: Lefty]
#607755
02/09/10 02:39 PM
02/09/10 02:39 PM
OldHippie
super gas
super gas
It has been a long time since I looked at Doug's Catalog so was not aware of the 451/452. If you are looking for larger tube size for a low deck you are still out of luck with the Doug's since the 451 has a 1 3/4" tube. I would be inclined to ship them back and tell Doug's to try again or give my money back. I had the transmission pan clearance issue on a '78 Dodge PU with a 400/727 combo. Collector flange hit the deep transmission pan about 2" down from the pan rail. Using the stock pan cleared that issue up but so would having a collector flange that was not welded from the manufacturer. Some guys are using the Hooker 5903 (?) Comp. header with Eddy heads with good results. 1 7/8" tube size, available with M/C coating, need to slightly ding two tubes for spark plug socket clearance, somewhat less than the Doug's and a whole bunch cheaper than TTI's. Zippy will back this up.
