Are '70 Satellite, RR, & Belvedere Grilles the Same? #607492
02/07/10 09:45 PM
02/07/10 09:45 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
Are the factory grilles on '70 Plymouth Satellites, Road Runners and Belvederes the same?
I'm building the Monogram '70 GTX kit as a Satellite and using the Road Runner kit's grille, as based on what I saw at www.hamtramck-historical.com , all three grilles appear to be the same, but maybe the small trim band around the grille's perimeter is the only difference?
The grilles in the following two pics appear to be correct for a Road Runner (and maybe for Satellites & Belvederes, too):
TIA.
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same? [Re: In_The_Pink] #607493
02/07/10 09:47 PM
02/07/10 09:47 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
They are the same, but the paint is different.
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same? [Re: pinkduster] #607494
02/07/10 09:48 PM
02/07/10 09:48 PM
Milwaukee, WI
Milwaukee, WI
Please elaborate. Color? Texture?
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same [Re: In_The_Pink] #607495
02/07/10 09:53 PM
02/07/10 09:53 PM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
In the pics you posted, you can see the outer band of the grille/bezels is light textured argent, with the vertical fin areas med. textured argent.
A standard Satellite/Belvedere grille is the exact opposite, outer band med. textured argent.....
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same [Re: mr_belvedere] #607496
02/07/10 10:03 PM
02/07/10 10:03 PM
Milwaukee, WI
Milwaukee, WI
Great info. Thank you both.
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same [Re: In_The_Pink] #607497
02/07/10 11:12 PM
02/07/10 11:12 PM
ohio
CumminsExpress Offline
ohio
the gtx is honey comb not straight lines
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same [Re: CumminsExpress] #607498
02/11/10 07:34 AM
02/11/10 07:34 AM
challenger2008 Offline
Parts Problem
Parts Problem
HONEY COMB? IM HUNGRY GOT SOME MILK
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same [Re: challenger2008] #607499
02/11/10 09:39 AM
02/11/10 09:39 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
The Sport Satillite (2dr, 4dr, vert or wagon) and GTX have the honey comb grill
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same? [Re: In_The_Pink] #607500
02/11/10 10:57 AM
02/11/10 10:57 AM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Satellite and belvedere also did not have plymouth off to the side,it had a red,white and blue emblem in the CENTER.Its a emblem that is about 8" long by 1 or 1 1/2".
Re: Are '70 Satellite, RR, & Belvedere Grilles the Same [Re: 70RR383] #607501
02/11/10 05:26 PM
02/11/10 05:26 PM
Northern Indiana
super gas
super gas
Northern Indiana
Sorry, but SPORT satellite was the only '70 PLymouth b-body that used the red/white/blue emblem in the center of the grille.
Belv., Sat., RR all used the 'Plymouth' emblem on the left side of the grille.
