I called on a project car last night. Turns out it was sold. But just before I hung up the guy he says he has another project, that is decently rust free but has had the inner fenders cut out.
Unfortunately, it had the shock towers cut as well.
He has the parts for the shock towers, but I really don't know how important it is to have exact alignment of the new shock towers to factory specs.
Here's where I need help - the shock towers are simply welded to the front frame rails, and protrude upwards and terminate under the inner fenders. The rails are fine and rust free. Here's my take: those old cut up shock towers would just need the rest cut off, remove the old welds on the frame (grind etc), position new parts, weld on new parts, and done?
> Then position new inner fenders and weld, and done?
Anything else I'm missing for a job like that? It's a simple mount point for shocks, so it probably doesn't need alignment to factory specs within a few thou, correct?
opinions?
Thanks guys,
Darren
