Re: Best Street Gear Ratio?? -HELP
[Re: A4SixtyNineRR]
#60631
05/20/08 10:34 PM
05/20/08 10:34 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Whats wrong with the 3:23? I had that in my cuda and it would light the tires up just fine plus would top it out at around 140 MPH. I have a 2:76 in my dart thats a 4 speed that roasts the tires off. Sell me your 3:23 if you don't like it.
[Re: Dart 340]
#60632
05/20/08 10:43 PM
05/20/08 10:43 PM
Posts: 292 dead center
CHRONiklyDEMONic
Demonized
Demonized
dead center
3.55.
"After a Day filled with burning Rubber, you may find it time to re-tire."
[Re: A4SixtyNineRR]
#60633
05/20/08 10:45 PM
05/20/08 10:45 PM
roadrunners where light to light terrors.. NOT hiway cruizers.. so stick some 4.30's in there.
[Re: Dart 340]
#60635
05/20/08 11:38 PM
05/20/08 11:38 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I'm gonna go against the grain here. I run 3.91's in my Satellite, and love them. But, My car is used around town only. It rarely sees freeway miles, and when it does, I'll admit its not exactly the hot ticket! If you do any freeway miles, I'd go with 3.73's, just so you can peek at 60 MPH below 3g. If its just a Saturday Night Special, and you're in it for the fun factor.....3.91's are fun. Heck... 4:10's!!!
[Re: CHRONiklyDEMONic]
#60636
05/20/08 11:40 PM
05/20/08 11:40 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
3.55. The best gear choice ever. Period. My friend has a fox body mustang that run's 7.90 in the 1/4 mile, with a 3.55 gear.
why would anyone care what your friend has...
[Re: StealthWedge67]
#60638
05/21/08 12:57 AM
05/21/08 12:57 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have a 2.76 in my 318 cuda and it will lite em up real good. It is great on the highway unless I plan to break a speed limit at all, then I wish I had even higher. I would use the 3.23 or higher for cruising and especially considering MPG these days.
[Re: HotRodDave]
#60639
05/21/08 01:37 AM
05/21/08 01:37 AM
8-3/4 is a pretty quick swap, enough practice and you can change gears in 20 min. I have 3.91 in my runner and like it, but change to 2.76 for the highway. If I had 4.88 I would probably use that for bursts about town. I do like 3.55 as an all around gear.
[Re: Mr.Yuck]
#60642
05/21/08 09:29 AM
05/21/08 09:29 AM
i drove with 4.30's on the hiway with a 28" tall tire at 60-65mph.. wasn't all that bad.
[Re: Pacnorthcuda]
#60645
05/21/08 11:12 AM
05/21/08 11:12 AM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
Not to high jack but would a swap to a 3.73 or 3.91 from a 3.23 be noticable and how much will it affect the top end?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: Kudakidd]
#60648
05/21/08 11:31 AM
05/21/08 11:31 AM
355's in my 69 roadrunner is just right
