416 stroker buildup
#606243
02/06/10 06:11 PM
02/06/10 06:11 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Im in the works of building a 416 for my cuda. Right now the plan is for 10:1 compression, ported 2.02 J heads (don't know the flow numbers), Holley 750 double pumper, Edelbrock RPM Air Gap or LD340 (have both), Comp XS272 236/242@50 .502/.511, Hooker competition headers with 2.5" exhaust with flowmaster super 40's. Any guesses on what it will make and if it could possibly 11's? It will be in street trim with a 4 speed and it has 3.23's right now but will probably try 3.91s or 3.73's if I can find them.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: 416 stroker buildup
[Re: 73cuda340]
#606244
02/06/10 08:31 PM
02/06/10 08:31 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
the stroker motors eat up duration and thats a small cam to start with I am running a 246/254 .590 right now and its to small I would look at a little more cam
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Ian]
#606248
02/07/10 07:16 PM
02/07/10 07:16 PM
73cuda340
clarks summit pa
Any cam recomendations? It will be mainly a street car so I dont want anything that will kill the bottom end.
[Re: 73cuda340]
#606250
02/07/10 09:55 PM
02/07/10 09:55 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I can't give info for anything that I haven't tried,but a UD solid 251@.050 IS a bottom end torque cam in that combo,not a big rpm cam at all with the limited heads we generally use on a street engine.Call Tim @ bullet racing cams and give him all the info for a great cam for your needs. These smaller cams that you are looking at would be fine in a truck,or VERY mild street car/truck.
[Re: goldmember]
#606251
02/07/10 11:31 PM
02/07/10 11:31 PM
73cuda340
clarks summit pa
Would you guys recommend a solid cam for the street or just stay hydraulic?
[Re: 73cuda340]
#606252
02/07/10 11:33 PM
02/07/10 11:33 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
With stock type heads I'd stay hyd. You won't ever rpm enough to need a solid with those heads.
[Re: goldmember]
#606253
02/08/10 12:30 AM
02/08/10 12:30 AM
Posts: 27,477 So Cal
autoxcuda
So Cal
I can't give info for anything that I haven't tried,but a UD solid [Email]251@.050[/Email] IS a bottom end torque cam in that combo,not a big rpm cam at all with the limited heads we generally use on a street engine.Call Tim @ bullet racing cams and give him all the info for a great cam for your needs. These smaller cams that you are looking at would be fine in a truck,or VERY mild street car/truck.
So a Comp XS272 236/242@50 .502/.511 is truck cam. Like RV duty??
[Re: autoxcuda]
#606254
02/08/10 01:29 PM
02/08/10 01:29 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Cam's too small (and you may have detonation issues with a true 10:1 and open chambers with it) and teh carb is too small. There is no loss of low end with a stroke longer than any factory big block. A similar build I did a couple years ago runs close to the same setup: 9.6:1 forged dishes, ported (by me) "308s", a Crane 248°/258° hydraulic cam, and a Street Avenger 870 VS carb. Makes about 460ish hp by the mph/weight. Running a 750 dry flowed carb on these tends to give them a big drop in power around 5500. Least every one I drove with one does...lol. Like turning off a light switch.
That XS272S is a truck cam, yes. Like an RV cam.
[Re: OA5599]
#606256
02/08/10 05:11 PM
02/08/10 05:11 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I have one suggestion. I run Dynomax Ultraflos and temperarily switched to a 40 series 2 chamber VX series (Flowmaster replica). I didn't get 100 yards in the car and noticed it was way down on power. I like the sound and get way more compliments with the Ultraflos too. I switched back and gained all of the power I had lost. This was on a low 13 sec 8.5:1 340 with no stall. I'm sure they would hold back your stroker even more than they held mine back. I have read similar stories after doing some research.
Ultraflos burnout and drive by: http://www.youtube.com/watch?v=3aiKrwGXFOo
Ultraflo muffler vid http://www.youtube.com/watch?v=xrqvMTafr_c
40 series muffler http://www.youtube.com/watch?v=6x29VdPkEZI
Chambered mufflers sound great but they definitely cost power. There is NO DOUBT about this.
[Re: 73cuda340]
#606260
02/10/10 11:07 AM
02/10/10 11:07 AM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
416 in my 3780lb.Challenger,heads-Eddy OOTB,10.4:1 compression, M1 Single plane, holley 750 Vac sec. Hooker Super Comps, cam is Comp hydralic 240/253 with 508/525 lift, 727 with a 4.30 gear I ran 11.97 @ 112 second time out. Traction is definetly an issue. I'm running an automatic and power brakes so you could run a bigger cam with the 4 spd.
[Re: 73cuda340]
#606262
02/11/10 10:25 PM
02/11/10 10:25 PM
Posts: 892 USA
krw71ragtop
USA
416" with this Scott Brown cam made 451 hp @ 5700 rpm's 502 ft lbs tq @ 4100 rpm's, with OOTB Edelbrocks, 10.1 comp. wiseco pistons, K-1 rods and crank, 750 holley, airgap intake.
