STUCK pistons ADVICE #606063
02/06/10 03:11 PM
02/06/10 03:11 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
I've got to break the pistons out of a 383 - Assuming the rings are all stuck - I have no intention of re-using the pistons - would like to save the rods if possible - the caps are off the rods and crank but the crank is stuck because all the pistons are frozen in place - the block is important to the care ( numbers) Any ideas to make this as easy as possible? AND is anyone making 383 pistons 10:1 comprssion .30 over? Thanks!!!!
68 Satellite Wagon and a few other ones
Re: STUCK pistons ADVICE [Re: mro] #606064
02/06/10 03:18 PM
02/06/10 03:18 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I've never tried it, but have heard of guys pouring a can of Coke over the piston and let it soak for a day or two. My uncle messes with antique tractors and has freed up several stuck motors using this meathod.
Re: STUCK pistons ADVICE [Re: mro] #606065
02/06/10 03:21 PM
02/06/10 03:21 PM
Put some diesel fuel or kerosene on top of them for several days. Worst case scenerio might have to drill a bunch of holes in each piston top to free up the piston walls. Would be time consuming but with it being a #'s matching block I wouldn't do much pounding on the pistons. When you get it rescued you'll soon forget about all the labor it took but if you crack the block you'll be upset for a long time.
Re: STUCK pistons ADVICE [Re: mro] #606066
02/06/10 03:28 PM
02/06/10 03:28 PM
AndyF Offline
AndyF  Offline
Just bust them out of there. Use a steel rod up from the crankcase and hit it with a 5lb sledge hammer. Cast pistons will easily bust. You can usually only get a few pistons at a time so you have to work your way around the block. Hopefully you can bust the stuck ones and then rotate the crank enough to get to the next ones.
Re: STUCK pistons ADVICE [Re: 6pkaar] #606067
02/06/10 03:29 PM
02/06/10 03:29 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
1.)Mopar rust penetrant.Soak each cyl several times.It will eventually free up.
2.)A few shots with a dead blow hammer should help.
3.)If 1 or 2 doesn't work if may be neccesary to break the top of the piston.
Leave the gun.......take the Cannoli's....Mike
Re: STUCK pistons ADVICE [Re: mike s] #606068
02/06/10 03:52 PM
02/06/10 03:52 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
If the penetrating oil doesn't do the job. Pool acid, muriatic acid. Dilute some muriatic acid and pour it between the piston and the cylinder wall. Wait about ten to fifteen minutes and then pour some water/baking soda solution over the piston to neutralize the acid. Then drive the piston out. The pistons will be a total loss.
You are probably going to bore the engine, I wouldn't worry about damaging the cylinder wall with the acid.
The acid does two things, dissolves any aluminum that may have fused to the cylinder wall and dissolve any rust between the rings and the cylinder wall.
Be careful, the acid is not user friendly. Use appropriate clothing and a safety shield. You don't want this stuff on your skin, eyes or clothing. Keep a bucket with water/baking soda solution handy for accidental spills or splashes.
Re: STUCK pistons ADVICE [Re: Snoopy] #606069
02/06/10 05:20 PM
02/06/10 05:20 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
If you're in no rush you can also try plain ATF. Pour enough in to cover each piston completely and let it sit.
Re: STUCK pistons ADVICE [Re: Reggie] #606070
02/06/10 10:19 PM
02/06/10 10:19 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I've soaked with whatever then take a 2x2x4 chunk of wood on end beat with a maul on intake side and exhaust side of pistons,once u get the to rock a little they will come right out.Another way I got them to move was with a hydraulic bottle jack and log chain, put the bottom of the jack on top of the piston wrap the log chain around the block & over the ram then start jacking(if you are accident prone don't do 2nd one)
Mitch
Re: STUCK pistons ADVICE [Re: AndyF] #606071
02/06/10 10:28 PM
02/06/10 10:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Big This is what I used last time
Re: STUCK pistons ADVICE [Re: mro] #606072
02/07/10 11:56 AM
02/07/10 11:56 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you need to be careful just busting them out , a friend punched a hole thru a cylinder wall doing it that way once .
As far as your 10.0 .030 piston request , the only piston that will get you that is the KB400 DOME piston , the factory OVERATED the 383 , the only way to get that compression ratio with a flat top piston is to deck the block so the piston is poking above the deck .020 and using a cylinder head with a 79.5 cc chamber with a steel shim gasket ... assuming 906 open chamber heads ...
Re: STUCK pistons ADVICE [Re: JohnRR] #606073
02/07/10 01:05 PM
02/07/10 01:05 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I find a piece of cut firewood the closest diameter, and hit that. It spreads the force over the top of the whole piston, and keeps from damaging the cylinder wall with the hammer. Works pretty good! But you have to soak it for days first, usually I use diesel fuel.
Re: STUCK pistons ADVICE [Re: 4BBodies] #606074
02/07/10 02:48 PM
02/07/10 02:48 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Lots of good advice here....I freed up a 440 by using PB blaster rust penetrant, a 5 lb. maul and a stack of hockey pucks taped together to beat on. Cut a hole in small piece of wood just larger than the bore dia. to protect the top of the block in case you miss the hockey pucks. Worked for me and all of the pistons were stuck. Good luck!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: STUCK pistons ADVICE [Re: 70gtx440dana] #606075
02/07/10 03:01 PM
02/07/10 03:01 PM
California
1970mopar Offline
1970mopar  Offline
California
Take it to your local engine machine shop and have them quote you for the job. I bet they will be able to do it for less $$ than you think and you won't have the issues of possible damage trying to do it yourself .
Re: STUCK pistons ADVICE [Re: 1970mopar] #606076
02/07/10 09:00 PM
02/07/10 09:00 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
It's going to the machine shop anyway for the .030 bore!
Re: STUCK pistons ADVICE [Re: 69MOPE] #606077
02/07/10 09:08 PM
02/07/10 09:08 PM
Be sure & tell THEM it's a valuble block and not to beat on it as they could very easily delegate that job to the lowest man on the totem pole and the BFH might appear (to him) to be the appropriate tool for the job.
Re: STUCK pistons ADVICE [Re: mro] #606078
02/07/10 10:00 PM
02/07/10 10:00 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
The only tip I can add to the above is to clean the bores above the pistons with some coarse sandpaper before starting. If you don't do this they'll fight you all the way out and require lots more pounding with the bfh.
Re: STUCK pistons ADVICE [Re: @#$%&*!] #606079
02/09/10 12:26 AM
02/09/10 12:26 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Diesel fuel works well. I got some out with Kroll penetrating oil also. I agree with lightly sanding the cyl's above the slugs so the will come on out once they are free'd up. A hammer and a piece of wood to work them around in there. Good luck with it and just take your time.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: STUCK pistons ADVICE [Re: StandOnIt] #606080
02/09/10 07:38 AM
02/09/10 07:38 AM
wisconsin
72dak Offline
72dak  Offline
wisconsin
ive dealt with alot of frozen engines and the best luck ive ever had was with pb blaster. make a pool on top of each piston and let it sit for a couple hours, roll it over and try to pound them
out using a wooden dowel or hammer handle. if some still dont move, dont rule out frozen wrist pins, i had a locked up 383 because of 1 frozen pin. if this is the case fill the bottom of the piston while its upside-down and try again later but be careful for cyl. damage as the rods may not move smoothly. good luck
Re: STUCK pistons ADVICE [Re: 72dak] #606081
02/09/10 12:27 PM
02/09/10 12:27 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
May sound strange but the last one I incountered my Grandfather showed me how to get it out. We went out and got some Dry Ice. Remember handlying with caution. Packed above the piston with it and covered it over with a section of plywood. We made a piece of wood as close to the diameter of the cylinder as we could. After a short with using the wood block we made and a hammer we pounded it down out the bottom of the block. Didn't take much work and didn't damage the block. Shocked the snot out of me but he did this a lot on trucks that he rebuilt.
1979 Chrysler 300 1968 Barracuda project
Re: STUCK pistons ADVICE [Re: LS-300] #606082
02/09/10 12:33 PM
02/09/10 12:33 PM
Az
Crizila Offline
Crizila  Offline
Az
Cool ( pardon the pun ) idea!!!
Fastest 300
