My 69 Rr steering box had been leaking on steering arm shaft ,I had put a seal in it ,but still leaked ,found another box in my stash ,look better ,replaced seals in it ,decided i would replace pump hoses also ,can,t stand leals ,put it all together ,now it poors out steering arm shaft ,pulled cover of unit cleaned ,made sure nothing was no valves were sticking ,put back toghter ,still pours fluid out lower shaft ,pulled seal out ,nothing wrong ,i,m stumped here ,Don,t know what to do now ,any ideas ,too much pressure Etc ,i ruined seal pulling it ,will be monday before i can,t get another ,Any ideas ,shaft seems tight ,not too much play
