Demon carb power valve? #60573
05/20/08 09:20 PM
05/20/08 09:20 PM
Maryland
dduster73 Offline OP
Maryland
I have an 850 Mighty Demon on my 440, and am trying to tune the carb.It has a 6.5 power valve and is pulling 10" vaccumm at idle 1200 rpm.How do you determine what size power valve to change to? Thanks Dave
Re: Demon carb power valve? [Re: dduster73] #60574
05/20/08 10:45 PM
05/20/08 10:45 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
If you have more vacuum than the power valve, then you are ok.
There is some good tuning info out there.
www.4secondsflat has a tuning video, and a tuning guide available
Re: Demon carb power valve? [Re: dduster73] #60575
05/21/08 12:31 AM
05/21/08 12:31 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
1200 RPM is pretty high for an idle. The vacuum reading should be done in gear, warm, and as for which power valve, I have read either 1/2 of the reading, or 2 sizes below the reading.
