Re: Synthetic vs. conventional oil?
[Re: 05dakota]
#605509
02/09/10 02:29 PM
02/09/10 02:29 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
so you think your modern fuel injected/computer controled car still fills the oil with fuel?
Not nearly like the carburated engines but fuel dilution is not the only contaminant that is there. There is always condensation to contend with, specially in the cooler months of the year when it takes longer running time to evaporate it out. to say nothing of carbon particals, dust that gets in past the filters. Do what you please but for the little bit it but for th e price of oil I will change at my regular lower intervals, thank you.
[Re: 05dakota]
#605510
02/09/10 02:47 PM
02/09/10 02:47 PM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
"fills" is strong but there is certainly some fuel, moisture and combustion contaminates that make there way into the oil, its unavoidable. To believe otherwise is foolish.
[Re: GTXKen]
#605512
02/09/10 04:45 PM
02/09/10 04:45 PM
Posts: 4,866 N. of 8mile, S. of heaven
Spike
Go Blue!!
Go Blue!!
According to a special report released by the Motor & Equipment Manufacturers Association (MEMA), synthetic motor oils are key to extended drain technology: “Extended drain technology is primarily based on the availability of synthetic oils. While the additives in conventional, non-synthetic oils allow them to function longer than the tradition 3,000 miles, it is primarily the synthetic base stocks that allow the oil to last much longer. Synthetic oil offers many advantages in durability versus conventional petroleum oil and it is all based on the synthetic oil’s superior heat and oxidation resistance.
Synthetic oil is more accurately controlled at the molecular level and therefore can be engineered to resist the forces in an engine that work against oil durability.”
Dark oil does not indicate the need for an oil change. The way modern detergent motor oil works is that minute particles of soot are suspended in the oil. These minute particles pose no danger to your engine, but they cause the oil to darken. A non-detergent oil would stay clearer than a detergent oil because all the soot would be left on the internal engine parts and would create sludge. If you never changed your oil, eventually the oil would no longer be able to suspend any more particles in the oil and sludge would form. Fortunately, by following the manufacturer's recommended oil change interval, you are changing your oil long before the oil has become saturated. Remember, a good oil should get dirty as it does it's work cleaning out the engine. The dispersant should stop all the gunk from depositing in the oil pan.
A look at many recent model owners manuals reveals a recommended 5000 to 7500 mile oil drain interval, while European vehicle manufacturers recommend even longer drain intervals.
The implications of the extended drain interval on the automotive aftermarket are mixed. There are two clear losers – the quick lube industry and the oil filter industry. According to a past National Oil and Lube News, Marc Graham, then president of Jiffy Lube International, said that for every 100-mile reduction in fast lube customers’ oil change intervals, the industry could realize $105 million in sales. Clearly, the converse is true, so a widespread extension of drain intervals would have an immediate and negative impact on the industry. This could be partly offset by the need for synthetic oils which traditionally command a premium that might help compensate for the lost volume.
The only real way to determine whether oil is truly in need of changing is to have an oil analysis performed. Since most people don't want to bother with this, it's acceptable to err heavily on the safe side and simply follow the manufacturer's recommended change interval for severe service. There are still a few cars that specify 3K intervals for severe service, but not many. If you look at countries other than the U.S., the oil recommended change interval is much higher than even the normal interval specified by vehicle manufacturers in the U.S
[Re: 05dakota]
#605513
02/09/10 05:00 PM
02/09/10 05:00 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Those analysis don't prove much of anything as every car is different. Cars with 100,000 miles are going to have a little less ring seal and get a little more metal particles in the oil than a 10,000 mile engine and the way every engine is driven will change how fast it contaminates oil in the future so a blanket statement like "you can go 10,000 miles on our (snake) oil" are foolish statements desighned to sell you their kind of oil. Also as for the manufactures stateing their cars can go for sooooooo long on an oil change are kinda pulling the wool over your eyes also. If you look in the owners manual fine print then 95% of drivers never drive in "normal" conditions and if you don't drive in their "normal" conditions you have to change the oil every 3000 miles. Another little trick of the makers is to make the sump bigger and obviously it takes longer to contaminate 6 qts of oil than 4 qts in the older engines. Above all of it there is still a trade off because as soon as you start driving on your fresh oil change there is contaminates in it and they increase as long as you drive, you just have to make a trade off about how long you want your engine to last, for example you could change the oil and coolant every 1000 miles under normal driving and most engines would last longer than the owners will live but you got to decide that for the price of 5000 oil changes over the course of 500,000 mile you could buy a lot of motors, just pick your poisen and decide what compromise you want to make ![](/ubbthreads/images/graemlins/Twocents.gif) For me I change it every 3000 religiously and I just use the generic brand as long as it has the latest API rateing and am happy that I have cars go over 200,000 and 300,000 miles without blowing motors. When the motor is newer you can let it slide a little longer but as the engine wears it gets contaminated faster and should be changed more frequently depending on how long you want it to last. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: CompSyn]
#605516
02/09/10 06:21 PM
02/09/10 06:21 PM
GTXKen
super gas
super gas
Contaminates… You guys need to think outside the box of the limited abilities of traditional paper cellulose oil filters…
Paper vs. Glass Oil Filter Comparison - link
Interesting read, if the filter and the oil are both improved then a longer interval can be achieved for sure. The problem in my situation is that I can't apply this to my 97 intrepid with 170K on it, the oil monitoring does not exist and it leaks/burns a quart every 3 months or so.
So maybe for my next car I can go synthetic and go 7500+ miles but not on anything I currently own.
[Re: MoparforLife]
#605517
02/09/10 10:18 PM
02/09/10 10:18 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
It is not the oil wearing out that the problem is, it is the contaminants that get ito the oil that do the damage and there are contaminants that the filter cannot take care of. Even the owners manuals that come with the Dakota we hav and the Chrysler van recommend oil changes at no more that 3000 miles under normal driving conditions, 7500 miles if under ideal driving conditions, like continual hiway miles. The same recommendation whether using regular or sythetic oils. The same contaminants get into the oil either way. It really is funny how you people can spend so much money on an engine or vehicle and then try to scrimp a couple of bucks on an oil change by extending the mileage intervals of a change. Oil is still cheap maintenance.
my todays oil's and filters can go longer than in the past, but the problem that we see is customers don't check anything between changes and that causes other problems, running low on oil, burning up motors and other things. Car companies also use mileage intervals as a marketing tool, " you can save with our car because of lower maintenance costs " or giving away free maintenance for certain time frame and since the warranty will be up before motor problems will kick in they can do this. If you drive mostly highway and check your fluids and tires often then yes you can go longer, but most people don't, that is why I still recommend changing 3,000 miles with conventional oil and 5,000 miles with ![](/ubbthreads/images/graemlins/boogie.gif)
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: deansrr]
#605518
02/10/10 07:24 AM
02/10/10 07:24 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Dean,
I partly agree with you on this. A large part of safely extending oil change intervals is simply educating people on the virtues of periodically checking their oil levels, tire pressures, air filter, etc.
Unfortunately, for some auto repair specialists, they’d rather the customer be dependent on them so they come back through the service door as much as possible. Some auto repair specialists might even be so bold as to say their customers actually enjoy coming back every 3,000-miles/3-months just so the they can shoot the breeze and get caught up on the latest. This may true for some, but for others, they may actually appreciate the option of money savings and convenience offered to them by extended service life synthetic motor oils.
Back to the first sentence. There is also the reality that some people won’t periodically check normal maintenance items even if they are reminded. Some of these same people may even put off taking their vehicle in for an oil change because they get too busy or forget. So again, why not promote a motor oil that’s formulated and capable of extended life service?
I strongly believe auto repair specialists and their customers alike would greatly benefit from extended life synthetic motor oils. For example, click on THIS LINK
[Re: deansrr]
#605520
02/10/10 05:58 PM
02/10/10 05:58 PM
CompSyn
Pacific NW USA
we do try to get customers in a high mileage/Synthetic oil, older people are stuck in there ways and don't want to switch, no matter what facts you show them, younger customers do switch or their car came with Synthetic and don't think they have to do anything else, this is where the problem is, maybe it's a yuppie thing. anyway thats how we can out motors more often. Can i sell you good Valvoline Oil??
If I were average joe car owner and knew nothing about motor oils and my oil change specialist offered me the option to switch to a Premium Synthetic oil at double the cost of conventional petroleum oil, I might ask if the synthetic can go twice as long and if it's actually warranted by the manufacture for extended use. If not, why would I want to pay extra for synthetic?
The truth is, many good name brand synthetic motor oils have no problem surviving past a traditional 3000-mile oil change interval, but they are not marketed or warranted for extended use.
[Re: dOc !]
#605522
02/11/10 06:25 AM
02/11/10 06:25 AM
CompSyn
Pacific NW USA
Hey CS ... ![](/ubbthreads/images/graemlins/wave.gif)
....a 3k mile oil-change-interval ? .... whatever happened to that proposed 25k "interval" ?
25k interval... Nothing has happened to it. 38-years and still going strong. In fact, I've got the 35k stuff in my car right now.
Must have misread the last post?
[Re: chuck2112]
#605524
02/11/10 11:42 AM
02/11/10 11:42 AM
RapidRobert
Chuck welcome aboard and there are no dumb Q's. Fire away ![](/ubbthreads/images/graemlins/thumbs.gif) . The problem is that filters (even the best) only catch some of the particles plus there's the problem of the soluble contaminates like acids/sludge/carbon etc. And even if the solubles were dealt with in some fashion you still wouldn't be able to go too small on the filter material micron size as you'd reach a point where the flow is restricted. It's comparable to when you were kids and your mom would clean several of you and your siblings in the tub one right after another & after so many kids in there you just reach a (saturation) point where the only thing left to do is change the water
[Re: RapidRobert]
#605525
02/11/10 05:07 PM
02/11/10 05:07 PM
Spike
Go Blue!!
Go Blue!!
Actually Chuck Amsoil makes a filter system for exactly what you are talking about. All you do is change the filters(two) and top off the oil. These are not your ordinary run of the mill filters. AMSOIL EaBP Filters have an efficiency of 98.7 percent at two microns. At normal operating RPMs the EaBP Filter will filter all of the oil in a typical five quart sump in less than 10 minutes. For more info Amsoil by-pass filter system.
[Re: RapidRobert]
#605526
02/11/10 06:59 PM
02/11/10 06:59 PM
CompSyn
Pacific NW USA
Chuck welcome aboard and there are no dumb Q's. Fire away . The problem is that filters (even the best) only catch some of the particles plus there's the problem of the soluble contaminates like acids/sludge/carbon etc. And even if the solubles were dealt with in some fashion you still wouldn't be able to go too small on the filter material micron size as you'd reach a point where the flow is restricted. It's comparable to when you were kids and your mom would clean several of you and your siblings in the tub one right after another & after so many kids in there you just reach a (saturation) point where the only thing left to do is change the water
In 1988, the Society of Automotive Engineers conducted a study on the correlation between contaminants and engine wear. They found that contaminants in the 2 to 25 micron sizes directly correlates to engine wear. They also found that paper cellulose oil filters were ineffective at this while oil filters that used glass media where highly effective. Further, glass media oil filters have been proven to flow better and last much longer than paper media oil filters, something industrial and commercial markets have known for 20-years. Now we are starting to see the glass oil filters for automotive applications.
As far as motor oil goes, the first motor oils were non-detergent so they needed to be changed more often. This is where the 3000-mile oil change recommendation came from which goes back to as early as the 1930s. Today, we have motor oils with detergents in them. Detergents help control acids, sludge and keep contaminates suspended in the oil so the oil filter can filter them out. Based on the quality and quantity of these detergents, a motor oil can be designed or formulated for increased service life. One such detergent that is measured is called Total Base Number (TBN), which is commonly found in manufacture Product Data Sheets (PDS).
Total Base Number (TBN) is the measurement of a lubricant’s reserve alkalinity, which aids in the control of acids formed during the combustion process. The higher a motor oil’s TBN, the more effective it is in suspending wear causing contaminants and reducing the corrosive effects of acids over an extended period of time. A high TBN motor oil allows it to effectively combat wear causing contaminants and acids, providing superior protection and performance over extended drain intervals.
This is why vehicle fleet managers look at the remaining TBN content of motor oil. They do Used Oil Analysis to determine if a motor oil is still fit for service. A TBN value of 1 would be considered low and the oil would have to be drained and replaced. This is why a motor oil with a higher starting TBN value can effectively have a longer service life.
For example, look at some of the starting TBN values of these top brand motor oils:
This is why some oils are marketed as extended life oils and some are not. It's all in what you want and what you're willing to pay.
So again, if we keep the oil clean through efficient oil filtration and we use a motor oil that is formulated for longer service life, then extended oil changes are completely safe and doable as long as the engine is mechanically sound.
