Re: 2 MSD boxes blown up. Ideas
[Re: Slipknot440]
#605303
02/05/10 08:21 PM
02/05/10 08:21 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Have seen people have this problem when the box is not grounded properly. They need a good ground...preferably to the battery negative terminal. Most people don't run it to the battery, but MAKE SURE you have a GOOD ground to the frame or chassis with good clean connections/terminals.
If you like drag racing, support your local track.
[Re: Slipknot440]
#605305
02/05/10 09:45 PM
02/05/10 09:45 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Actually one mallory and one MSD in 2 months and the billet distributor got fried. Drove the car less than 300 miles and have had these three problems any guesses as to why? I put the old orange box and MP distributor back on, how much performance will i lose compared to above?
IMHO your much better off leaving the MSD (Might, Sputter & Die) system off the car, ...Orange boxes of late, have been having quality control issuses, some say as of "recent", but IMHO the last 3-4 yrs seems more likely......I'd be more apt to remove the electronic ignition, the ballast resistor, orange, or any fruity colored box and install a Pertronix converted Chrysler distributor, you'd need a point type (single prefered) dist. to perform this upgrade to a HallCell, if performed properly can offer a truely troublefree, and upgraded ignition system not frought with the maladies that the Electronic or MSD often encounter in service
Mike
[Re: DAYCLONA]
#605307
02/05/10 11:16 PM
02/05/10 11:16 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Depending on your combo, a good mopar style ignition box will be fine.
I'd recommend an upgrade to a chrome one, or an aftermarket perf version like the FBO unit.
Depending on cam, you really only need the msd in the lower rpm ranges. Above 3k or so, it's single spark, just like a regualr moapr unit.
A good ecu will keep a straight curve with the distributor, no matter what brand name is on it.
Lesser ones, can't keep up at higher engine speeds. I've spun several on my distributor machine. Stock units, start to fall behind around 4500. oranges between 5 and 6 depending on which one you get, and a chrome or an FBO will keep it together to 8k or so.
[Re: joedust451]
#605312
02/06/10 07:03 AM
02/06/10 07:03 AM
Posts: 5,910 Athens, Greece
Pyper70
Athens, Greece
I say ground only because that was what I ran into. I had my MSD6AL box inverted upside down (which they say you aren't supposed to do anyways) behind my glove box applique right above the glove box door on a 70 Charger. I ran a 12gauge wire to a chassis ground. It made an odd buzzing sound but MSD said that some units do that, nothing to worry. It burned out one day and I had to buy a whole new unit. This time the guy at the speed shop said to mount it right side up and run a steelbraid cable from the MSD to the firewall. Never had a problem with it again.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Slipknot440]
#605314
02/06/10 09:51 PM
02/06/10 09:51 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I would call up MSD, they used to have great tech support and will repair you MSD as well. As I mention on the other thread you may consider a capacitor. From MSD... If you experience radio noise after installing the MSD Ignition, you may need to install an MSD Noise Filter. Electro Magnetic Interference (EMI) is occasionally generated from the MSD power cables and can be easily eliminated by installing the Noise Filter on the heavy power supply wires coming from the MSD. When the MSD draws current, it will draw through the Noise Filter instead of directly from the battery, so all other accessories that operate off 12 volts, like the radio, fuel pump, or the engine computer, will be unaffected by the MSD. The Noise Filter will also prevent damage to the MSD during jump-starts and will keep a vehicle's 12-volt line clean by removing any voltage and current surges that could interfere with the operation of some MSD accessories such as the Soft Touch Rev Control or the Two Step Module Selector. It is recommended that the Noise Filter be used on installations with the MSD 7 and 8 Series Igni�tions to prevent this interference. http://www.jegs.com/InstallationInstructions/100/121/121-8830.pdf
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
