Re: 1967 440 with 915 heads
[Re: redmist]
#605198
02/05/10 05:56 PM
02/05/10 05:56 PM
RapidRobert
1st Q would be what do you want out of for performance? and what is it going into and how much money do you have to spend
[Re: RapidRobert]
#605199
02/05/10 06:02 PM
02/05/10 06:02 PM
Posts: 305 5th and plum
redmist
5th and plum
I would like to build a car that can cruise on the street and still run mid 12's for well... CHEAP It is going into a 1968 Dodge Charger.. I have a few performance parts floating around already. I had originaly planned on building my 383, but that looked like a pain in the ass piston wise.. Then this 440 popped up on craigslist so I jumped on it. I would love a streatable 500 HP.. Money is not a HUGE problem as I am not in a hurry to finish it, just a fun project.
[Re: redmist]
#605203
02/05/10 11:29 PM
02/05/10 11:29 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I am picking up a 1967 440 with 87,000 original miles on the motor. It has the 915 heads on it.. Would it be possible to do a re-ring and bearings and then just run it?
Are the 915 heads a good start to a build?
Thanks!!
Ryan
You'll have to tell us on the rering and bearings. Only way to tell is to tear it down.
I bought my 67 440, planning to do it that way. Turned out one of the rods was spun really bad (had to go .030") In any case, I put in the six pack slugs, and put it together with a racer brown 242@50 cam. and a set of 452's(didn't come with th3 915's when I got it). It worked well, and put the car in the mid to high 12's with 410's, a 3K stall, headers, and a rpm intake.
I switched it up to the 915's a year later. Used 1.6/1.5 combo rockers, switched it up to the 174 exhaust valve, home ported, and that put her down into the 11's.
Picking the right balance of cam, and streetability will make or break it for you.
[Re: redmist]
#605209
02/06/10 10:03 PM
02/06/10 10:03 PM
redmist
5th and plum
Also just went through my parts from my old 383 that I stripped down.. (it's been 9 years) and I have these parts already for the 440 that can swap over. Crane Gold 1.5 roller rockers TCI "rattler" dampener Milodon PAN and Pickup Mellings HV Pump Mopar Aluminum water pump AND housing 1&3/4" headers Hughes HE2330 camshaft (may change that) Cloyes double roller gear and chain 3 bolt And a few other small parts. This is going to be FUN AGAIN!
