What size/type bolts for engine stand?
#603980
02/04/10 06:34 PM
02/04/10 06:34 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
What size and or type bolts do I need to attach a 440 to an engine stand like this? Do I need a specially hardened bolt or will ace hardware bolts work?
Re: What size/type bolts for engine stand?
[Re: challenger70]
#603982
02/04/10 06:49 PM
02/04/10 06:49 PM
RapidRobert
5/16" I believe and just get the right length so you have ~1" or so of engagment into the bell face. Yes grade 5 (3 lines) will be good enough.
[Re: challenger70]
#603990
02/04/10 07:44 PM
02/04/10 07:44 PM
Challenger 1
Cincinnati, Ohio
I have found from experience that IMO, grade 5 3/8"-16 all thread rod is the way to go. The reason being is I can screw it all the way into the block by hand and make sure it's bottemed in the hole in the block. I don't have to worry about if it's in deep enough because it's all the way in. Then after you have all four rods bottemed in the block, bolt the engine stand head to the motor before it's on the engine stand. Slide four washers on the all thread and run your nuts up and your as good as you can be without using grade 8 all rod which I never was able to find. I have found some engines have deeper tapped holes than others so all thread rod works in all cases.No need for washers under the bolt head and then hoping you got enough thread engagement. YOU DON'T NEED GRADE 8 BOLTS. Then the short block is easy to get into the hole on the engine stand. Two of us an lift a sb shortblock with the engine stand head bolted to it into the base of the engine stand. I can honestly say I've had 50 different engines on this stand with these peices of all rod and has never broke. Big block gas truck engines too with 7/16" all rod I have laying around here. 30 of the claimed 50 of those engines were huge hemis.
[Re: Challenger 1]
#603991
02/04/10 08:26 PM
02/04/10 08:26 PM
RapidRobert
A recent Mopar Muscle issue had a full page of Harbor Freight coupons including a cherry picker for $99.50 plus your local sales tax. I couldn't pass that up for $107 & change.
[Re: gtx6970]
#603992
02/04/10 08:27 PM
02/04/10 08:27 PM
Challenger 1
Cincinnati, Ohio
Check around, I bet one of your friends has a cherry picker they will let you use. Check with rental yards.
rent or borrow a cherry picker, you back will thank you many years from now
I was at the tool rental the other day and I saw those old towable engine cranes sitting way in the back of his warehouse. I said to him, it don't look like those go out much because they were buried with other tools in front of them. He said they rarely rent them anymore because of all the 99 dollar chinese lifts. Hell I bought one a couple years ago because it folds up more compact for my little garage at home. I use it for light duty work, but I still have my slide togeather one for big block work that I bought from the tool rental about 25 years ago. It was a big investment for me at the time, but I rented enough times to warrant buying it. It's way better than my foldup crane, like what is pictured above but a hassel to break down when I'm done with it. Tools like these(engine hoist) are good investments if your gonna mess with motors.
[Re: RapidRobert]
#603993
02/04/10 10:04 PM
02/04/10 10:04 PM
Posts: 1,375 Costa Mesa, CA
chache876
Costa Mesa, CA
They had that thing on sale for $129.99 (reg 179.99) and I had a 20% off coupon so I picked it up for cheap as well a couple weeks ago
