Electrical fire
#602311
02/03/10 03:03 AM
02/03/10 03:03 AM
Posts: 374 CONNECTICUT
RoyceFlo73
CONNECTICUT
So, i did an intake manifold gasket and a tune up. I reconnected everything accordingly. But when i turned the key, NOTHING. I rolled the car outside to jump start it. So, i put jumper cables on her and tried again. Still nothing, after about 10 mins of banging on the starter and checking all my wires I decided to give up and try again tomorrow.
Instead, as a i shut my hood a few minutes later i saw smoke. Opened the hood and the blue wire that runs from the alternator to the first wire harness clip was Red hot and cooked the insulation off the wire. the whole wire all the way to the fuse block was toast.
This all happened outside and its snowing. I do not have the time right now (all happened at about 1am) to check everything to see if it toasted anything else. But, WHAT HAPPENED!!!!
I didn't touch any electrical aside from removing the plug wires to get the intake off. My best guess would be some spilled coolant caused a short somewhere? or when i put the wires along the valve covers again maybe i pinched two together or something stupid?
ANY ideas, I am ridiculously mad at this, i just got it all tuned and ready to get going, then outta left field, this happens. My luck.
Re: Electrical fire
[Re: bordin34]
#602320
02/03/10 07:16 PM
02/03/10 07:16 PM
RapidRobert
be sure and locate the dead short before you R&R the harness. EDIT do this by unhooking the battery and with your VOM on ohms check any place/every connection along the fried wire(s) until you find where there is continuity to ground as there's a dead short (to ground) somewhere there and or there was too much current flowing from that circuit being overloaded & if it was in the main feed from the batt in to the under dash then out to the alt it'd be the circuit being overloaded but iirc you said the field circuit I'd be pretty sure a dead short to ground rather than it being full fielded or near full fielded for an extended period of time especialy since it happened when the car was shut off. Good luck. Holler when you discover something.
