Re: What's the difference - Stealths and Pro-Comp heads?
[Re: VITC_GTX]
#602266
02/03/10 02:02 AM
02/03/10 02:02 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Stealth's are sort of cross between a 906 iron head and a Eddie Performer.84 and 86 cc chamber available.Ported they flow slightly less than the Eddie's.
Pro comps are knock offs on the Eddie Victor cyl heads.Small chamber 72cc ? and issues with pushrod clearance esp with a low deck engine.More flow potential due to much larger port volumes than the Stealth's and Eddie performers.They require offset intake rockers.
Of the two the Stealths are best for your combo.
Two different cyl heads for two different purposes.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#602272
02/03/10 03:20 PM
02/03/10 03:20 PM
Posts: 7,497 Austin, TX
HemiDave
Austin, TX
Are you saying that PORTED Stealths flow less than UNPORTED Eddies? [/quote
NO just slightly less than ported eddies.
I have both the Stealths and the Pro Comps. Stealths would be better for your combo.
As for which flows more ported...might depend on who ports them, too....
