convertor question #601744
02/02/10 04:37 PM
02/02/10 04:37 PM
pacific northwest
Stroker Scamp Online content OP
Stroker Scamp  Online Content OP
pacific northwest
gonna send my convertor back to PTC for a freshen up, convertor flashes at 5200-5300 in drive, im gonna attach the dyno sheet,just wondering if any gain can be had by tweaking the stall? any opinions welcome,
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: convertor question [Re: Stroker Scamp] #601745
02/02/10 04:43 PM
02/02/10 04:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
when you say drive what gear are you talking about? stall should be checked in 3rd gear rolling abot 5-10 mph.
Re: convertor question [Re: Quicktree] #601746
02/02/10 04:49 PM
02/02/10 04:49 PM
pacific northwest
pacific northwest
sorry bout that was 3rd gear rolling
Re: convertor question [Re: Stroker Scamp] #601747
02/02/10 04:51 PM
02/02/10 04:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
ok people are going to need a lot more info about your car and combo probably to help you out. I myself like a loose converter.
Re: convertor question [Re: Quicktree] #601748
02/02/10 04:56 PM
02/02/10 04:56 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The best way to check flash rpm is using the trans brake if you have one. Just warm it up pull the low side chip engauge the brake in low and stand on the throttle. It will show you were its at.
If the converter flashes in the 5200-5300 range..its very close to idea matched to that power table...Almost always you want the converter flash around or near peak torque..This is usually around 1000-1200 rpm below peak rpm.. And your right there...
Have you calculated slippage yet? If its good, dont bother sending the converter back..the only thing it will change is your bank account total.
BTW
I feel that converters long with cams isnt rocket science.People like to over complicate things too much. There is no black magic in converters or cams. If its setup and in the correct application, and in the ball park for what is idea, your not going to see huge gains like people think between "his" or "There" custom converter or camshaft..
Unless you think a few hundredths is a bunch
Re: convertor question [Re: Bob_Coomer] #601749
02/02/10 05:09 PM
02/02/10 05:09 PM
pacific northwest
pacific northwest
regarding slippage,, that last two runs on the car slowed, over 1/2 second and 7 mile per hour, (my trap rpm was up a little) i havent run the car since, so im basically trying to figure out why it slowed, the fluid was still bright red with no smells of burning, already checked the basics on the motor.
Re: convertor question [Re: Stroker Scamp] #601750
02/02/10 05:18 PM
02/02/10 05:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
was your 60' off?
Re: convertor question [Re: Stroker Scamp] #601751
02/02/10 05:45 PM
02/02/10 05:45 PM
detroit mich
stevehiss Offline
stevehiss  Offline
detroit mich
when mine did that the sprag in thr convertor was bad
I DARE TO BE DIFFERENT
Re: convertor question [Re: Quicktree] #601752
02/02/10 07:15 PM
02/02/10 07:15 PM
pacific northwest
pacific northwest
was your 60' off?
60' was slower by 1/10
Re: convertor question [Re: Stroker Scamp] #601753
02/02/10 08:10 PM
02/02/10 08:10 PM
What do you shift at?
Re: convertor question #601754
02/02/10 10:34 PM
02/02/10 10:34 PM
pacific northwest
pacific northwest
ive tried 6 to 6500 best et was at 6500 10.24 130
