Dash Wiring help Please!!!! part II
#601259
02/01/10 10:26 PM
02/01/10 10:26 PM
Posts: 386 Maryland
reno340
Maryland
![](/ubbthreads/images/graemlins/smilie_help.gif) I am working on the dash wiring in my 72 Duster 340. When I bought the car it somehow had a dash harness from a 73. I had the dash out and had worked on the dash wiring. Using a schematic, I had traced out and rectified any discrepencies. I put it in and hooked it up today. I have no rear body harness hooked up yet. The Problem that I had run into is that when I turn on the ignition, the turn signal flasher makes a noise as if the signals are on. Nothing changes when I turn on the turn signal in either right or left position. the front park/turn signal bulbs do not light using the turn signals. The park lamps work fine. The black wire to the flasher is hot when I turn on the ignition switch. The red wire is not. I don't remember if that changes (red wire) when I use the turn signal. Black wire still remains hot. The flashers work fine. I am also having some problems with the wiper motor. I haven't fully checked it out but noticed that it barely moves past 1/4 inch. (as if the motor is very weak) Any help would be appreciated. ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Dash Wiring help Please!!!! part II
[Re: reno340]
#601260
02/02/10 01:01 AM
02/02/10 01:01 AM
Posts: 386 Maryland
reno340
Maryland
[Re: reno340]
#601262
02/02/10 11:08 PM
02/02/10 11:08 PM
Posts: 386 Maryland
reno340
Maryland
I wanted to get the flasher to stop making the flasher clicking sound and was curious as to what is wrong as it is going to bug me until I find out why.
Re: Dash Wiring help Please!!!! part II (update)
[Re: Paul_Fancsali]
#601265
07/01/10 10:20 PM
07/01/10 10:20 PM
Posts: 386 Maryland
reno340
Maryland
I have an update to my problem. I have since hooked up the whole system, added a ground to the steering column and tested the turn signal switch. I found the switch to be faulty and bought a new switch and hooked it up. (not installed in steering column yet) I turned on the hazzard lights and yahoooo, I've got 4-ways!! I used a 20 amp circuit breaker w/ alligator clips and used it in place of the fuse for my turn signal/heater blower motor/? location on the fuse box. I turned on the ignition and turned on the signal and I had turn signals both ways! I think I turned off the inition switch and turned it back on to test the heater motor again. I do know that I turned on the heater blower motor and it ran fine. somewhere along the way it ended up that my original problem of the signals not working and the signal flasher clicking when the ignition is on even when the signal is off. I disconnected the heater blower motor switch and tried it again but the clicking and no signal lights continued to be a problem. I do not remember if any of this happened because of depressing the brake but I don't think so. (it has been over a week since all of this transpired). What gives? BTW, I do not think the under dash harness is incorrect as it is pretty consistant w/ the wiring diagram other than some of the fuse box (and none of the schematics I have looked at from 72-73 has matched completely) Any help would be greatly appreciated! ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: screamindriver]
#601266
07/01/10 10:29 PM
07/01/10 10:29 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
I generally don't charge any of the electrical system up until it's completely done...You run into all sorts of strange issues with incomplete circuits and improper grounding...Lights and components will backfeed looking for a path creating all kinds of strange situations...FYI the flasher needs all the bulbs hooked up{and grounded} to work properly...As stated don't get too excited until you finish the wiring then see how it works..
until my side marker lights where in,my front parking lights came on everytime i hit the brake,left dir. worked right stayed on,hook up all first or you will be chasing your tail ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: meepmeep70]
#601267
07/01/10 11:17 PM
07/01/10 11:17 PM
Posts: 386 Maryland
reno340
Maryland
I think you mis understood, it is all hooked up and I am having these problems. Maybe I should have separated the update from the original post. ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
