How do u remove thrust spacer on 8-3/4? #600901
02/01/10 05:20 PM
02/01/10 05:20 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
My understanding is that the pin in the SG unit has to be removed when adding axles with green bearings.
If that is the case how does the pin come out? Do I need to take the SG unit apart? Probably a dumb question but ya'll need a laugh occasionally.
Russ:)
BigBlock 74 Swinger
Re: How do u remove centering pin on 8-3/4? [Re: bb74swngr] #600902
02/01/10 05:21 PM
02/01/10 05:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I thought all you had to do was remove the buttons not the shaft.
Re: How do u remove centering pin on 8-3/4? [Re: bb74swngr] #600903
02/01/10 05:25 PM
02/01/10 05:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on whether it's a clutch type or cone type Sure-Grip. The clutch type can be removed without disasssembly, just drive out the roll pin that holds the two halves together; the cone type must be split to remove the thrust block.
There is debate on the need to remove the thrust pin/block, I think it's a good idea but others.........
Re: How do u remove centering pin on 8-3/4? [Re: John_Kunkel] #600904
02/01/10 05:32 PM
02/01/10 05:32 PM
Missouri
mopar addict
mopar addict
Missouri
Thank you John! Is the SG that you can't see the springs through the sides the clutch type?
I don't know anything about SGs...be gentle:)
BigBlock 74 Swinger
Re: How do u remove centering pin on 8-3/4? [Re: bb74swngr] #600905
02/01/10 05:39 PM
02/01/10 05:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, if there isn't a large opening with visible springs it's the clutch type.
Re: How do u remove centering pin on 8-3/4? [Re: John_Kunkel] #600906
02/01/10 05:55 PM
02/01/10 05:55 PM
Missouri
mopar addict
mopar addict
Missouri
Hi Richard! John, with what Richard posted, can I get the thrust spacers out without removing the roll pin? Do the thrust spacers just set in there or are the held in place by something?
BigBlock 74 Swinger
Re: How do u remove centering pin on 8-3/4? [Re: bb74swngr] #600907
02/01/10 06:12 PM
02/01/10 06:12 PM
scratchnfotraction Offline
I have run greens with the 489 cone sg for 8 yrs
I swaped in the 742 open and used a cold chisle to break the thust button(3 piece and accounted for)to keep from R&R the carrier
been running it that way for 1 1/2yrs so far
like said...some do...some dont...your call
if you have buttons...I would remove them and run it
get the better m-400 green bearings also
Re: How do u remove centering pin on 8-3/4? [Re: scratchnfotraction] #600908
02/01/10 06:32 PM
02/01/10 06:32 PM
Missouri
mopar addict
mopar addict
Missouri
How ya doin Mike! Do you know how the buttons are actually held in there? BTW I got the dipstick tube off. I won't be able to send them for a week or so.
BigBlock 74 Swinger
Re: How do u remove centering pin on 8-3/4? [Re: bb74swngr] #600909
02/01/10 09:02 PM
02/01/10 09:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The two halves of the thrust buttons are held by the "lock pin" shown in the pic I posted.
Without disassembling anything, use a long pin punch to drive out the roll pin and the two halves will separate. The roll pin is usually broken after extended use and each half just falls out.
Re: How do u remove centering pin on 8-3/4? [Re: John_Kunkel] #600910
02/01/10 09:52 PM
02/01/10 09:52 PM
Missouri
mopar addict
mopar addict
Missouri
Thank you John! I'm not the sharpest knife in the drawer but I think I understand now:) I can do this. Everyone is so good at this stuff, thanks again.
Russ:)
BigBlock 74 Swinger
Re: How do u remove centering pin on 8-3/4? [Re: John_Kunkel] #600911
02/02/10 08:19 PM
02/02/10 08:19 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I agree with the 'fall out'. Usually a long magnet will get them out.
If you like drag racing, support your local track.
