(Pic update) Griner tb valvebody #600840
02/01/10 05:05 PM
02/01/10 05:05 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
I went and bought me a used race 727 today and opened it up when i got home.
It was nothing about it that i wanted (stock servos, stock drums, stock clutches) but the vb looks to be something good. it apears to have a cast (not billet) machined bottom plate.
Is it true that Griner is the only vb with this feature?
I cant find any numbers or anything on it.
It also looks as if someone welded on top of the vb. Is this ok/normal?
Also the output shaft does not look like a stock piece, it is almost like gold colored, not the grey with black spots like the stocker.
Any idea what this is?
Also the frictionplates for the rear clutch is black in color with some metallic in it.
Are there any black frictions or are they just burned?
Re: Griner tb valvebody [Re: sshemi] #600841
02/01/10 05:30 PM
02/01/10 05:30 PM
Chicagoland
chargerron69 Offline
Chicagoland
the cast vb is trans act of indys vb looks like a griner but its not. black frictions are kolene (sp) and are plobably not burned unles the frictions are. hope this helps. tip, pics = 1000 words
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: Griner tb valvebody [Re: sshemi] #600842
02/01/10 07:22 PM
02/01/10 07:22 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
If it was a Griner... Griner would be cast into the bottom part.
Re: Griner tb valvebody [Re: 727specialist] #600843
02/01/10 09:05 PM
02/01/10 09:05 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
This is how my Griner vb looked. His name was machined into the bottom. Don
Re: Griner tb valvebody [Re: cudadon] #600844
02/02/10 03:28 AM
02/02/10 03:28 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
It does not look that nice, more like a machined cast piece.
Ill see if i can get some pics.
Re: Griner tb valvebody [Re: chargerron69] #600845
02/02/10 03:36 AM
02/02/10 03:36 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
I didnt mean that the steel plates are black.
The friction meterial is black
The steels look just like stock.
BTW does the black on the kolene wear out at some point?
Im gonna see if i can get some money back from the guy i bought it from so i can buy a billet front drum and billet servos and clutches and bands.
Re: Griner tb valvebody [Re: sshemi] #600846
02/02/10 01:21 PM
02/02/10 01:21 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
valvebody.
Anyone recognise this one?
Re: Griner tb valvebody [Re: sshemi] #600847
02/02/10 01:22 PM
02/02/10 01:22 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
2
Re: Griner tb valvebody [Re: sshemi] #600848
02/02/10 01:23 PM
02/02/10 01:23 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
front FLEX!! band
Re: Griner tb valvebody [Re: sshemi] #600849
02/02/10 01:25 PM
02/02/10 01:25 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
front clutch plates
Re: Griner tb valvebody [Re: sshemi] #600850
02/02/10 01:26 PM
02/02/10 01:26 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
rear band (kevlar) with grooves or weird wear?
Re: Griner tb valvebody [Re: sshemi] #600851
02/02/10 01:28 PM
02/02/10 01:28 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
rear clutch plates
Re: Griner tb valvebody [Re: sshemi] #600852
02/02/10 01:30 PM
02/02/10 01:30 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
lightened sun shell(sp)
Re: Griner tb valvebody [Re: sshemi] #600853
02/02/10 01:31 PM
02/02/10 01:31 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
rear drum
Re: Griner tb valvebody [Re: sshemi] #600854
02/02/10 01:33 PM
02/02/10 01:33 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
output shaft
Re: Griner tb valvebody [Re: sshemi] #600855
02/02/10 01:35 PM
02/02/10 01:35 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
overrunning atleast looks good.
Re: Griner tb valvebody [Re: sshemi] #600856
02/02/10 01:37 PM
02/02/10 01:37 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
another rear shaft
Re: Griner tb valvebody [Re: sshemi] #600857
02/02/10 02:02 PM
02/02/10 02:02 PM
Portsmouth, VA
DusterW2 Online content
DusterW2  Online Content
Portsmouth, VA
http://www.jegs.com/i/TCI/890/121900/10002/-1?parentProductId=746229
The valvebody is either a TranzAct or TCI copy. May or may not be rear band apply in 1st, but looking at your low/rev drum, it looks like you don't have a clean release during the 1-2 shift or some abuse. The output shaft is stock; the aftermarket 300M steel shafts do not have a speedo gear provision. The kevlar low/rev band with grooves is normal. Depending upon line pressure, alot of builders prefer the solid backed kickdown band with red lining. The flex band anchors, which are spot welded, can break with high line pressure.
John
Re: Griner tb valvebody [Re: sshemi] #600858
02/02/10 03:26 PM
02/02/10 03:26 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
The guy i bought it from said he new nothing about it so i guess i can only blame myself.
It was a spare for his 800 horse cuda that comes from the US. Looks like the "spare" have been used quite alot.
I know i dont wanna use it for my 800 horse Hemi.
I should have bought a new tranny from John Cope like i planned to.
Re: Griner tb valvebody [Re: sshemi] #600859
02/02/10 06:16 PM
02/02/10 06:16 PM
detroit mich
stevehiss Offline
stevehiss  Offline
detroit mich
never too late
I DARE TO BE DIFFERENT
