426 Hemi #600513
02/01/10 10:31 AM
02/01/10 10:31 AM
New England
Tech Instructor Offline OP
New England
I need some thoughts.Is 10.5 too much comp.for street engine with cast iron heads? I do not have cam selected yet.Engine will be in 65 b-body.Thanks
Re: 426 Hemi [Re: Tech Instructor] #600514
02/01/10 11:23 AM
02/01/10 11:23 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You should be fine with 93 octane and a not too aggressive advance.
For optimum tuning, I would go 9.5 so that I could really fiddle with the timing. After all, it is a Hemi...
Re: 426 Hemi [Re: Tech Instructor] #600515
02/01/10 12:12 PM
02/01/10 12:12 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Mine with cast iron heads came in at 10.2 and detonation is a non-issue. I had to deck my block due to surface issues. I wish I would have decked my block more to up my compression to 10.5
I have only ever used 93 oct pump gas and it gets raced regularly in summer months [30-35 passes a year]
Re: 426 Hemi [Re: pacifica] #600516
02/01/10 02:29 PM
02/01/10 02:29 PM
New England
New England
Thanks for the advice.I guess I will go with them.
