arp rod bolts,ly rods.torque specs? #600146
01/31/10 08:11 PM
01/31/10 08:11 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
was wondering what the torque specs were for the arp rod bolts.have them installed on ly rods for my 440
Re: arp rod bolts,ly rods.torque specs? [Re: 1bad318] #600147
01/31/10 08:14 PM
01/31/10 08:14 PM
50 w 30wt oil
Re: arp rod bolts,ly rods.torque specs? [Re: 1bad318] #600148
01/31/10 08:32 PM
01/31/10 08:32 PM
north carolina
K
kwik63 Offline
kwik63  Offline
K
north carolina
I will start assembly of a new 500" stroker for this season shortly. I have Eagle Rods with ARP bolts. ARP reccomends you measure the bolt "stretch" instead of using a Torque Wrench. This is new to me but I bought the calpiher tool they said to use. I am going to use this method and it makes sense. I have never had a problem with using a torque wrench on the several motors I have raced. Check ARP website or give them a call..I usually go 50 ft.lbs in increments on rod bolts. If you replace factory rod bolts with new ones it is not a bad idea to have them resized or at least checked for distorstion.
Re: arp rod bolts,ly rods.torque specs? [Re: kwik63] #600149
01/31/10 08:38 PM
01/31/10 08:38 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
hensley redid my rods.they resized,shot peened and installed arp bolts.i dont have a stretch gauge,had never heard of one till a few minutes ago.also,this a pump gas street 440,will make about 525 or so hp with a mild hydraulic cam,so its not a 8000 rpm monster
