Re: 50 truck on to 85 chassis, lower?
[Re: poorboy]
#600019
05/14/10 07:54 AM
05/14/10 07:54 AM
Posts: 19,555 north of coder
moparx
A paint gun would be nice, but a spray bomb will work too. May I suggest painting the underdash white? It really brightens things up when you need to climb under the dash to do something. Gene
gene is on the money with this tip. if white isn't quite up to your liking, a light machine grey will work well too.
[Re: poorboy]
#600022
05/16/10 10:14 PM
05/16/10 10:14 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
Too late,I used red primer rattle can. I did read the note before I primed the rest of the inner cab, so sprayed lite gray primer under there as much as I could. Thanks for the tip.
4bbl
If you can't hear it coming what's the point.......
[Re: 4bbl]
#600023
06/20/10 10:25 PM
06/20/10 10:25 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
Cab back on chassis, happy Father's Day.
4bbl
