transmission wont go in reverse or neutral? #599916
01/31/10 05:07 PM
01/31/10 05:07 PM
KY
juicedcuda Offline OP
KY
TF-727 wont go into reverse or neutral. It goes into first, second and third. In neutral, it is like park, the car wont budge. I checked the cable and linkage, it seems to be fine. The car is stuck on the trailer, LOL.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: transmission wont go in reverse or neutral? [Re: juicedcuda] #599917
01/31/10 05:19 PM
01/31/10 05:19 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Does it have a trans brake ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: transmission wont go in reverse or neutral? [Re: bigdad] #599918
01/31/10 05:31 PM
01/31/10 05:31 PM
KY
KY
no transbrake. I checked the fluid.
Re: transmission wont go in reverse or neutral? [Re: juicedcuda] #599919
01/31/10 05:42 PM
01/31/10 05:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pull the cable off the trans and see if you can
move the shift lever by hand(block the tires first)
Re: transmission wont go in reverse or neutral? [Re: juicedcuda] #599920
01/31/10 06:03 PM
01/31/10 06:03 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
With the engine not running, you should be able to push it in every gear except park if you just want to get it off of the trailer.
Re: transmission wont go in reverse or neutral? [Re: SuperStocker] #599921
01/31/10 06:05 PM
01/31/10 06:05 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you burned it up on the last pass and the clutches welded themselves together.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: transmission wont go in reverse or neutral? [Re: bigtimeauto] #599922
01/31/10 06:09 PM
01/31/10 06:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
if you put it in neutral while it is still running and it try's to move forward then the forward clutch is the welded culprit, the band would apply for reverse on that hub.
Re: transmission wont go in reverse or neutral? [Re: dartman366] #599923
01/31/10 06:20 PM
01/31/10 06:20 PM
KY
KY
The car won't move at all in neutral or reverse. Pulls forward in first, second and third. Car won't roll in any gear.
