69 Charger gauge problems...UPDATE
#599085
01/31/10 02:39 AM
01/31/10 02:39 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
The gauges on my 69 Charger dont work correctly. I have tried 4 different voltage limiters, and all of them have the same effect. The gas gauge will go up to empty when the key is tuned on, and when the tank is full, it will read 1/4 tank. The temp gauge doesnt move at all. I have replace the temp sending unit. When each sending unit wire is grounded, each gauge will go all the way up and peg. The cluster has a good ground as well. I dont mind the temp gauge not working for now, but I need to have a working gas gauge. I am going to pull the fuel sending unit and check that out tomorrow. If the gauge pegs when the sending unit wire is grounded, wouldnt that mean the gauge is good...more or less?
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: 69 Charger gauge problems
[Re: 69L78Nova]
#599086
01/31/10 02:52 AM
01/31/10 02:52 AM
RapidRobert
Correct. From the female electrical connector at the gas tank forward yes you are good. Make a long jumper wire w 2 alligator clips and connect the gas tank sending unit metal hose nipple all the way up to the battery negative post so you have a complete circuit & if you're then OK add an auxially ground wire from the sending unit base to the frame for a permanent good ground. EDIT Still bad? the sending unit inside the tank has a problem and since opening up the tank is such a pain I'd borrow another sending unit and mock it up outside the tank and move the arm thru it's travel & see if the gauge up front is OK.
[Re: RapidRobert]
#599087
01/31/10 03:00 AM
01/31/10 03:00 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Thats what I was thinking. It still has the clip on ground strap going from the sending unit to the fuel line, but Ill try to run a known good ground wire in the morning and see if that does anything. Also, I replaced the temp sending unit and that gauge doesnt work either, yet pegs when the wire is grounded. Not sure what to do about that one.
[Re: 69L78Nova]
#599089
01/31/10 07:30 AM
01/31/10 07:30 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
"Thats what I was thinking. It still has the clip on ground strap going from the sending unit to the fuel line, "
I hate that little ground strap. I soldered a length of 14ga cable to the 3/8" fuel tube on the sending unit, put a small hose clamp around it and then put an eyelot terminal on the other end to the chassis. You know you have a good ground there and its simple to do. ( I did all this out of the car )
Check all your grounds. You should have at least 5 on your car but the more the merrier. Radiator to battery, battery to block, block to chassis, starter to chassis, steering column to steering post, gauge cluster to steering post.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: 69L78Nova]
#599093
01/31/10 04:34 PM
01/31/10 04:34 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well, I pulled the sending unit (lost about 7 gallons of gas all over the garage floor), and found the float to be cracked. I replaced the float, soldered a ground wire from the sending unit and connected it to the body. I have a good engine to body ground, core support to battery ground, made a cluster to steering column ground, and have a new ground cable. The temp gauge and gas gauge still dont work. I dont get it. Any other ideas I can try?
[Re: 69L78Nova]
#599095
01/31/10 05:10 PM
01/31/10 05:10 PM
Posts: 5,445 So Cal
Sinitro
So Cal
To fix the guages once & rite.. You should pull the rally dash, next check each guage for correct movement gas, temp and oil. They are actually 5V meters and their respective sending units are variable resistors that shunt the meter's voltages. While the cluster is out check the guage PCB, resolder where necessary and validate the voltage limiter and grounds.
Then once all is corrected, bolt it back in. Yes it is a pain to pull the dash but the only way to fixe it rite.
Just my $0.01..
[Re: RapidRobert]
#599098
01/31/10 06:44 PM
01/31/10 06:44 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Yeah, the gas gauge goes from below empty as it would be with the key off, to way past full with the wire grounded. The temp gauge is reading just a hair over 120 with the engine at operating temperature with the new sending unit. The oil pressure gauge kinda hangs around 20, at idle all the way up the RPM range. Ill put it up in the air again and try to find a wire long enough to run up to the battery. I guess for peace of mind, Ill order up a new voltage regulator for the cluster. Cant hurt right?
[Re: RapidRobert]
#599100
01/31/10 07:21 PM
01/31/10 07:21 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
To eliminate future problems after I resolve matters at hand, where would I obtain an electronic voltage limiter? I read the step-by-step deal a while back on how to make your own, but does anyone sell them?
[Re: 69L78Nova]
#599101
01/31/10 07:36 PM
01/31/10 07:36 PM
RapidRobert
I remember somebody on here did but it was quite awhile back but I dont remember exactly who/where (on here) the ad was. EDIT just had a thought- R/T engineering??? something like that
[Re: RapidRobert]
#599102
01/31/10 10:21 PM
01/31/10 10:21 PM
Pyper70
Athens, Greece
I think you mean Voltage Limiter.....the one on the rallye cluster...the voltage regulator is in the engine bay.
When I had my cluster rebuilt I had AutoInstruments do it. They install a solid state voltage limiter, costs about $20 and supposed to be the real deal versus the cheap Napa chinese stuff. I am installing my rallye cluster on tuesday most likely
[Re: Pyper70]
#599103
02/01/10 10:55 PM
02/01/10 10:55 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well, I changed the voltage limiter yet one more time. Now the temp and oil pressure gauges read correctly, so I put a DVOM on the fuel senging unit, and no matter where you move the arm, it reads open. Now is there a good place to get a new one? I was looking at Mancini just because Ive had good luck with their parts and service in the past. Id assume they are pretty much made by the same manufacturer for the most part, right?
[Re: 69L78Nova]
#599104
02/02/10 01:02 AM
02/02/10 01:02 AM
RapidRobert
Might eyeball the contact that rides over the windings & see if you can CAREFULLY bend it so it has constant tension on them to make contact thru it's travel. If no go do some checking as there's been some sending units that do not read correct so you might post a Q on the best one to get so your gauge will end up reading right especialy after all the bad luck you've had w this. I want it to where when the gauge is squarely on the E that I have about 5 miles of traveling left
