70 B body tach hole #599026
01/31/10 12:46 AM
01/31/10 12:46 AM
Kelowna, B.C. Canada
DPelletier Offline OP
There was a thread here a while back, but I guess I forgot to print out the info sooooo:
Can anybody tell me the size and location of the hole in the firewall for the factory grommet used on a 70 B body with a tach? Pics?
I think it's right next to the bulkhead wiring block, but....
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 B body tach hole [Re: DPelletier] #599027
02/01/10 11:21 AM
02/01/10 11:21 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Here is a picture....not sure on the size!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 B body tach hole [Re: 70gtx440dana] #599028
02/01/10 12:22 PM
02/01/10 12:22 PM
Thanks a bunch!
hmmm, not where I thought it'd be; is it a factory tach car? What is the cable directly opposite the firewall bulkhead connector?
Cheers,
Re: 70 B body tach hole [Re: DPelletier] #599029
02/01/10 12:49 PM
02/01/10 12:49 PM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
I added a factory tach to my Road Runner many years ago. I had aquired an original tach harness, and used a set of calipers to measure the narrow part of grommet then bought a hole saw at the local hardware store to match. I don't remember the exact size, but 1/2" comes to mind. It was a common size and the grommet fit perfectly.
Re: 70 B body tach hole [Re: Paul] #599030
02/01/10 02:54 PM
02/01/10 02:54 PM
Thanks Paul; was it in the same location as the one in the picture above?
Re: 70 B body tach hole [Re: DPelletier] #599031
02/01/10 04:49 PM
02/01/10 04:49 PM
Lansing, MI
Lansing, MI
Blue and black wires next to gray tach wire are for the headlight door system on a 70 Charger. I am not sure about the other cable/wire you are questioning without having a look underhood.
Re: 70 B body tach hole [Re: 70gtx440dana] #599032
02/02/10 01:15 AM
02/02/10 01:15 AM
RT03 Offline
RT03  Offline
This is where the tach hole is drilled on my 70 GTX. It's a factory tach car. The hole diameter is about .830".
Re: 70 B body tach hole [Re: RT03] #599033
02/02/10 12:10 PM
02/02/10 12:10 PM
Ahhhh; that's where I thought it should go as opposed to the grey car pictured above.....
Thanks!
Re: 70 B body tach hole [Re: DPelletier] #599034
02/02/10 01:19 PM
02/02/10 01:19 PM
Lansing, MI
Lansing, MI
Dave,
Here is another picture of a tach wire. It only adds more confusion. I guess I would like to see a few more unmolested cars to confirm.
Re: 70 B body tach hole [Re: RT03] #599035
02/02/10 01:28 PM
02/02/10 01:28 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
I currently have two Super Bees in the shop, a 68 and a 70, both are original tach car and both have holes in the same place as your GTX.
Mike
Re: 70 B body tach hole [Re: rocketresto] #599036
02/02/10 02:15 PM
02/02/10 02:15 PM
Well, we have 3 different locations listed but three cars which people have stated are original tach cars have them in the same spot as the pic of the '70 GTX, so that location is in the lead so far!
Thanks guys; if anyone has any more info or pics; lets see 'em!
the holesaw is coming out in the next couple of days!
Re: 70 B body tach hole [Re: DPelletier] #599037
02/02/10 02:19 PM
02/02/10 02:19 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
curious
Re: 70 B body tach hole [Re: DPelletier] #599038
02/02/10 02:35 PM
02/02/10 02:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Add another.. Coded for tach...
Re: 70 B body tach hole [Re: 1_WILD_RT] #599039
02/02/10 02:56 PM
02/02/10 02:56 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's my February '70 LA built GTX - original tach hole.
Re: 70 B body tach hole [Re: 6bblgt] #599040
02/02/10 03:01 PM
02/02/10 03:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The evidence is mounting...
Re: 70 B body tach hole [Re: 1_WILD_RT] #599041
02/02/10 04:30 PM
02/02/10 04:30 PM
Yeah, I agree: I'm just about ready to declare a winner!
Thank you to everyone who posted!
Re: 70 B body tach hole [Re: DPelletier] #599042
02/02/10 07:57 PM
02/02/10 07:57 PM
sixbbl69 Offline
sixbbl69  Offline
tach hole diameter 13/16"
Re: 70 B body tach hole [Re: sixbbl69] #599043
02/02/10 08:01 PM
02/02/10 08:01 PM
Thank you.
Re: 70 B body tach hole [Re: DPelletier] #599044
05/12/10 01:05 PM
05/12/10 01:05 PM
Ohio
70BIRD Offline
70BIRD  Offline
Ohio
This thread came to mind as I'm installing the wiring in my car...I have a factory tach (70RR) and and I have the hole between the bulkhead and the master cylinder as shown in some of the pics above so that's no problem.
What I'm confused about is in the new dash harness I have there are the black (w/red tracer)and blue (w/yellow tracer) wires that are fed thru a large conical shaped rubber grommet that someone above states is for the headlamps on a 70 Charger.
So on my car are these wires are just left to hang under the dash unused?
Thanks,
Paul
Re: 70 B body tach hole [Re: 70BIRD] #599045
05/12/10 05:45 PM
05/12/10 05:45 PM
Lansing, MI
Lansing, MI
These wires are for 70 Charger only. They run the headlight motor to open the doors. You will not need them on a RR. New harness must be generic. I would tape up the connector and even possibly tape this entire pigtail to your harness under dash.
