Re: 70 B body tach hole
[Re: DPelletier]
#599047
05/12/10 06:17 PM
05/12/10 06:17 PM
Posts: 579 Ft.Myers,Florida
Hemiruss
Ft.Myers,Florida
Dave the problem is your car is metric and is in the other side,It's a Canadian Thind..........lol lol lol...I thought you'd get a kick out of it from our past post exchanges......lolololololllool
Russ....it's the big one in the middle....
[Re: MrNormsTA]
#599048
05/12/10 06:27 PM
05/12/10 06:27 PM
Posts: 3,054 USA
b54406barrel
USA
I really didn't care about the hole, but figured some purist might not like it down the road, so why do it.
Years ago I had a wrecked 69 Charger dash & put the tach/clock in my 6bbl rr as it didn't have either. Once I found out how crappy (this was in the 70's) it was & hard to read, I took it out. Glad I didn't drill that hole!
[Re: 70gtx440dana]
#599049
05/12/10 09:11 PM
05/12/10 09:11 PM
Posts: 108 Ohio
70BIRD
Ohio
These wires are for 70 Charger only. They run the headlight motor to open the doors. You will not need them on a RR. New harness must be generic. I would tape up the connector and even possibly tape this entire pigtail to your harness under dash.
I got the harness from Year One a few months ago and it was listed for 1970 Dodge and Plymouth models with oil gauge and I think it was made by M & H. In any event I'll tape up the connector and move on.
Thanks for the response.
[Re: sixbbl69]
#599050
05/13/10 12:41 AM
05/13/10 12:41 AM
Posts: 380 Mesa, Az
GETX
Mesa, Az
tach hole diameter 13/16"
[Re: 6bblgt]
#599051
05/13/10 09:32 PM
05/13/10 09:32 PM
Posts: 470 old New Jersey
papajohn
super street
super street
old New Jersey
Here's my February '70 LA built GTX - original tach hole.
Same as my Feb. '70 LA built Road Runner!
[Re: papajohn]
#599052
07/06/11 08:06 PM
07/06/11 08:06 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
I believe the tach grommet was feed through the hole punch above the bulkhead connector when the car was equipped with cruise control. I believe the grommet for the cruise utilized the "normal" tach positon.
As you can see on this '69 Charger R/T equipped with cruise, you can vaguely make out the single-lead tach wire harness out of the top position.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#599053
07/06/11 08:14 PM
07/06/11 08:14 PM
hemi68charger
Houston, Tx
Also, as was mentioned, '70 Charger headlamp harness would have been passed through the upper hole. The tach wire harness would have come out just like the B-bodies of '68-'69, the driver's side of the bulkhead connector.. Here's a picture of the firewall of my former '70 six pack Charger R/T without the tach option. The headlamp harness grommet came out above the bulkhead connector..
[Re: hemi68charger]
#599054
07/06/11 08:15 PM
07/06/11 08:15 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Could be; I thought it might be a Charger thing..... In any case I'm 99% sure that a non-cruise Superbee should have it in the lower spot across from the wiring block. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#599055
07/06/11 08:41 PM
07/06/11 08:41 PM
hemi68charger
Houston, Tx
Dave, If you're referring to the position between the bulkhead connector and the booster/master-cylinder like in papajohn's picture above, you are correct.......
Troy
[Re: 70gtx440dana]
#1817673
05/03/15 01:35 PM
05/03/15 01:35 PM
Posts: 16,149 Mesa, Arizona
dart4forte
Mesa, Arizona
Here is a picture....not sure on the size! That's about where my tach wire comes out on my GTS
Abe Lincoln
