Re: Thermoquad help needed [Re: 340rocks] #598818
02/06/10 02:32 AM
02/06/10 02:32 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
did you drill out your seats from the .093 to .110? it does seem that the 4972/4973 air metered carbs run a lot harder with a lot less mods than any other production t-quad.
Re: Thermoquad help needed [Re: ademon] #598819
02/07/10 12:34 AM
02/07/10 12:34 AM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
I had the car out last night. The jetting modifications worked just right. I made 5 passes and the A/F ratio was 12.7. The car picked up .05 in et and .5 mph. The weather was almost the same as last week, but the track was terrible. I spun on two of the runs. I did not get a chance to try openning or closing the air door because I ran out of time.
I'm not worried about the carb being rich at idle, I'm worried about it being right at full throttle. We were running metering rods that were .051 at the end and the primary jets were .091. That made the openning .040. I will start out with #71 Holley jets and go from there.
The carb is a 9077 and was built by a shop in St Louis. I don't know much else about it.
Thanks for the responses and suggestions. I made two passes at 11.87 and since my index is 11.85 I plan to go to the Division 7 race the end of the month. I have a set of radial slicks on order. I tied a set before and they were 1.3 faster then bias tires on my car. I'll probably be the lowest qualifier on the ladder, but at least I'll be able to dial the index or lower so I'll have a bit of a chance. I'll let you know how it runs.
Raul
Re: Thermoquad help needed [Re: Aspen7695] #598820
02/07/10 12:43 AM
02/07/10 12:43 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Anyone ever try making an adjustable stop for the upper limit of the metering rod tree? Couldn't you fab up a small threaded stop so at WOT the tree wouldn't go quite all the way to the top of it's travel? I would think that would allow you to tune the primaries leaner without pulling jets or rods...?
Re: Thermoquad help needed [Re: 340rocks] #598821
02/14/10 10:27 PM
02/14/10 10:27 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
moparmal just the end holes and can u go smaller dont know size of stock holes once drilled cant go back mine runs good now but would shoot frome the hip and hope for the best
DemonSizzler told me you can go as large as .055th on the end holes of the spray bars - He never mentioned drilling any of the other holes so I'd probably leave them as is.
Of course you need the motor to justify the extra work..I wouldn't bother unless your engine shows signs of "nosing over".
Removing the choke gear, and grinding the choke horn down at the front are other performance mods that appear to work.
Re: Thermoquad help needed [Re: Moparmal] #598822
02/14/10 11:07 PM
02/14/10 11:07 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Secondary spray-bar work ?
... my thoughts? .. I was going to add MORE but SMALLER holes(in new tubing) ... for better atomization of the fuel.
Re: Thermoquad help needed [Re: 1DGEMAN] #598823
02/15/10 01:19 AM
02/15/10 01:19 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A miss-fire will never show rich on an O2 sensor because it measures oxygen not fuel. If it miss-fires it won't use any oxygen so the sensor will actually read lean.
Kevin
Re: Thermoquad help needed [Re: dOc !] #598824
02/15/10 07:53 AM
02/15/10 07:53 AM
Moparmal Offline
Moparmal  Offline
Interesting thoughts......
