Trans. Dipstick Tube VS. Headers #598711
01/30/10 09:38 PM
01/30/10 09:38 PM
Ohio, USA
Dr-Dave2 Offline OP
Dr-Dave2  Offline OP
Ohio, USA
Im in the process of installing a 440 & 727 in my 66 Coronet 500 where a 318 Poly & 727 once resided.
I have a new reproduction dipstick and tube, I think it would be fine with exhaust manifolds but the #6 header tube is in the way (Hooker Comps.)
Would another body style dipstick be more vertical? or are those aftermarket flex ones the way to go?
Re: Trans. Dipstick Tube VS. Headers [Re: Dr-Dave2] #598712
01/30/10 09:48 PM
01/30/10 09:48 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
You can get a flex tube that fastens to your firewall. IMO that would be the way to go for ease of installation and use. I have the flex on my 408/727 (bolts to the bellhousing) in the Dakota and it is a pain because of the short length.
Re: Trans. Dipstick Tube VS. Headers [Re: Dr-Dave2] #598713
01/30/10 09:54 PM
01/30/10 09:54 PM
smyrna,tn
draginmopars Offline
smyrna,tn
if you are looking for function vs stock
I used a VAN tube.
was 518/small block
easy to reach now
nowhere near the headers
cut off the mounting tab-
relocate to the cylinder head
(rear/bolt hole near intake)
weld tab back on.
Re: Trans. Dipstick Tube VS. Headers [Re: draginmopars] #598714
01/30/10 10:45 PM
01/30/10 10:45 PM
Ohio, USA
Dr-Dave2 Offline OP
Dr-Dave2  Offline OP
Ohio, USA
I found this locking one at Summit
http://www.summitracing.com/parts/HUP-HP1235A/Application/?prefilter=1
Anybody ever use one?
Re: Trans. Dipstick Tube VS. Headers [Re: Dr-Dave2] #598715
01/31/10 12:50 AM
01/31/10 12:50 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Just bend the tube to where you need it to go.
Re: Trans. Dipstick Tube VS. Headers [Re: Magnum] #598716
01/31/10 01:42 AM
01/31/10 01:42 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I just did the same thing, big block swap with hooker comps. I just put the dipstick in, put a bolt just a few threads in to keep the mounting tabs hole lined up with where it was going to be bolted down, and bent it away from the number 8 primary. I bent the mounting tab so that the dipstick spun counterclockwise away from the primary, if that makes sense.
Re: Trans. Dipstick Tube VS. Headers [Re: GTX MATT] #598717
01/31/10 12:02 PM
01/31/10 12:02 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
put super comps in my truck last spring; (318/727) had to bend my trans dipstick tube on that one too; never had to with the old "alum a coats" we put in my brother's Ramcharger though.
I liked those headers they held up quite well; but I like the price I got this set of Hooker ones too. Considering that I "made do" and yes they ARE made for the truck chassis; not some others that were "modified" to fit. Evan came with the lil "instruction sheet" that said that bending of the dipstick tube may be necessary.
