What size extractors for SB stroker?
#598615
01/30/10 06:49 PM
01/30/10 06:49 PM
Posts: 96 Australia
gg408
Australia
W2 headed 410 stroker, what size pipes do you guys recomend? Was considering 1 3/4" stepped to 1 7/8" to 3" collectors or should I just go 1 7/8" straight of the bat. Street strip engine looking at around 550hp NA with about 150 spray. Cheers ![](/ubbthreads/images/graemlins/beer.gif) gg408
Re: What size extractors for SB stroker?
[Re: gg408]
#598616
01/30/10 07:45 PM
01/30/10 07:45 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my 416 with ported Indybrocks uses 1 7/8 with a 3 1/2 collector
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: gg408]
#598618
01/30/10 08:15 PM
01/30/10 08:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
There are a few things to consider... RPM is just one.... if you PM me I can run it through my header program.... but I'll need more info ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#598619
01/30/10 08:24 PM
01/30/10 08:24 PM
Posts: 2,530 PA
moparacer
PA
Dont go too big. Especially on that combination. I had a W2 headed small block in my dragster years ago and went from 1 3/4 1 7/8 steps to a set of 2 inch upswepts and it killed the bottom end.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: MR_P_BODY]
#598621
01/30/10 09:44 PM
01/30/10 09:44 PM
Posts: 96 Australia
gg408
Australia
PM Sent. Thanks Cheers ![](/ubbthreads/images/graemlins/beer.gif) gg408
[Re: gg408]
#598625
01/31/10 12:30 PM
01/31/10 12:30 PM
Posts: 4,213 New York
polyspheric
New York
Part of the choice depends on: 1. exhaust port CFM (high allows smaller pipe) 2. overlap window area (large may die with a large primary) 3. EVO event (early allows smaller pipe)
Bad port + late EVO = large primary.
Boffin Emeritus
