How to ID a 70 GTX?? #598152
01/30/10 11:12 AM
01/30/10 11:12 AM
Fort Wayne,Indiana 46845
mopar 394 Offline OP
I am looking at a 70 GTX RS23U0G car. It does not have the fender tag or build sheet. Besides the VIN on the door, radiator support and trunk lip is there a way to tell if it is a true GTX or a clone? I have not seen the car yet.
Re: How to ID a 70 GTX?? [Re: mopar 394] #598153
01/30/10 01:26 PM
01/30/10 01:26 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Some items to look for:
1)Skid plate on K frame & date on K frame should be close to build date of car
2)Dash vin, door vin, rad support vin, trunk lip vin, block vin & trans vin should all match
3)Dana 60 if it is a 4 speed car
4)Should have complete inner & outer trim set on rear tail panel
5)Should have wood grain rally dash assembly
Good luck!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: How to ID a 70 GTX?? [Re: mopar 394] #598154
01/30/10 05:42 PM
01/30/10 05:42 PM
ohio
B5 GTX Offline
B5 GTX  Offline
ohio
I think most if not all 70 gtx's had 26 inch radiators. Also the t bars would have been heavy duty .92". The rear springs would also be heavy duty. Not that these could not have been swapped, however if they are missing this might be something to questions as to why. The other thing to check for is the 3/8" fuel line, 383 runners would have been 5/16" (at least they are on 69's that may have changed in 70). You can never be to careful when buying one of these cars.
good luck
scott
Re: How to ID a 70 GTX?? [Re: B5 GTX] #598155
01/30/10 06:03 PM
01/30/10 06:03 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
RS in VIN# tells you it's a GTX
if the last 8 digits of the VIN# number match the core support and trunk lip, then the body matched the VIN# & it's a GTX.
STD radiator in a 440 and/or 440+6 GTX with an automatic is 22".
You need 4-speed, A/C or an axle package for it to be equipped with the bigger radiator.
Re: How to ID a 70 GTX?? [Re: B5 GTX] #598156
01/30/10 06:48 PM
01/30/10 06:48 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
good luck
scott
A 22" radiator was standard. 26" came on A/C cars and Trac Pac cars, Heavy duty trailer package, Taxi or Police, or you ordered the maximum cooling package
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: How to ID a 70 GTX?? [Re: 6bblgt] #598157
01/31/10 11:02 AM
01/31/10 11:02 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
