Engine offset in a 60s B-Body. #596992
01/29/10 01:22 AM
01/29/10 01:22 AM
Chicagoland
Cooter Offline OP
Cooter  Offline OP
Chicagoland
I don't have my chassis book with me or either car here, and I was curious what the offset was for a typical B-body. I never measured, and I was looking at different potential rear ends to swap in.
Whenever I am online I am totally naked. (Under my clothes)
Re: Engine offset in a 60s B-Body. [Re: Cooter] #596993
01/29/10 01:55 AM
01/29/10 01:55 AM
8" from outside edge of front framerail on drivers side to exhaust stud on front of the head.
5" same measurement except passenger side.
This is '63 Dodge with v-8 K frame, original BB motor mounts and 440 with 906 heads.
Re: Engine offset in a 60s B-Body. #596994
01/29/10 11:41 AM
01/29/10 11:41 AM
Chicagoland
Cooter Offline OP
Cooter  Offline OP
Chicagoland
Thanks, that helps quite a bit, since one car is a '64 Polara. I'm going to go out to the polebarn in a bit to measure the centerline of the driveshaft on the Coronet wagon next. I'm planning on using an Exploder 8.8 in at least the Coronet, since I can get them for less than 1/3 of the price of a 8 3/4 with 4.10s and a limited slip, they have disc brakes, and the width is almost exactly the same. The pinion offset on an exploder is pretty big, though.
Re: Engine offset in a 60s B-Body. [Re: Cooter] #596995
01/29/10 04:08 PM
01/29/10 04:08 PM
Let me know if you need other measurements.
My car is about 10 feet away in my attached garage and is easily accessed.
