Page 2 of 3 1 2 3
Re: 440 intake manifold [Re: Rug_Trucker] #596776
01/29/10 08:06 PM
01/29/10 08:06 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I think it is a little bit better than stock.
THERE you go !
Re: 440 intake manifold [Re: dOoC] #596777
01/29/10 08:27 PM
01/29/10 08:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
THERE you go !
Its all relative.
Re: 440 intake manifold [Re: BSB67] #596778
01/29/10 11:24 PM
01/29/10 11:24 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Here ya go guys, pics of 5 different 440 manifolds, aluminum 6 pack, performer 440 RPM, performer 440, Mopar 2836150, and Mopar (over the counter ??)aluminum with measurements from the driver side valve cover.
compare away.....
jt
Yeah, it's hopped up to over 160...
Re: 440 intake manifold [Re: jt4406] #596779
01/29/10 11:25 PM
01/29/10 11:25 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
sorry, reverse order
Re: 440 intake manifold [Re: jt4406] #596780
01/29/10 11:27 PM
01/29/10 11:27 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Performer
Re: 440 intake manifold [Re: jt4406] #596781
01/29/10 11:30 PM
01/29/10 11:30 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Performer RPM
Re: 440 intake manifold [Re: jt4406] #596782
01/29/10 11:32 PM
01/29/10 11:32 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Factory aluminum 6 pack
Re: 440 intake manifold [Re: Rug_Trucker] #596783
01/30/10 02:01 AM
01/30/10 02:01 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
YOU GUYZ and your CH4B !
IF that intake is superior to most intakes out there ... THEN WHY didn't Eddy repop that intake AS-IS .. just like it was produced back in the 60's ?
If you look at the results of the 383 intake shootout, the CH4B did very well in 'part 1' where they tested the intakes on stock heads. In fact I think it beat out the RPM in bottom end power IIRC. When they tested the intakes bolted onto a set of CNC ported aftermarket heads, the results were the other way around, but it's all realitive to your head flow and cam specs.
Re: 440 intake manifold [Re: DaytonaTurbo] #596784
01/30/10 03:01 AM
01/30/10 03:01 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Hey DT ...what does a 383 Shoot-out have to do with a CH4B ? .. the 383 intake that Eddy made that is similiar to the 440 one is a DP4B.
And again I ask ... if what you are saying is true ... why didn't Eddy just REpop these intakes AS-IS instead of all that R&D ? ...
Eddy did just-that with the TM-7 ...and Holley did just-that with the 440 Street Dominator.
Re: 440 intake manifold [Re: dOoC] #596785
01/30/10 08:38 AM
01/30/10 08:38 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Who on this thread stated that the CH4B is superior to anything but the stock intake? No one.
Because the design is very similar, it is reasonable to use the results from the DP4B test as a relative performance indicator for the CH4B. However, a stock manifold was not used in the test. Presuming the dyno was accurate in the test (big if) that would be, for a 383 b-body, about a 12.0 at 111 mph.
Edelbrock will make whatever they think they can make money on.
Re: 440 intake manifold [Re: BSB67] #596786
01/30/10 10:29 AM
01/30/10 10:29 AM
Central NC
gch Offline
gch  Offline
Central NC
IIRC the early ch4b intakes came with a chrysler part number and were sold through direct connection as well.
In the 440 intake shootout the ch4b did fairly well.It was down on low end tq compared to some dual planes but did well up top pulling peak hp at a higher rpm than all the other dual planes except for the rpm if memory serves.
I run one on my 496 in my c body because the rpm won't clear the hood with the factory air cleaner and it has much better bottom end than my street dominator(big heavy car).A performer will fit(barely touched the hood)but the ch4b pulls harder up top and rpm's higher w/o feeling restricted.
my 496 shifts at 5700rpm and will zing 6000+ with ported iron castings,small solid cam,and the ch4b intake with ease.It can move some air.The only mod I have done is have it deep port matched by Hughes engines.To keep the comparison even the same had bee done to my performer and sd as well.
Re: 440 intake manifold [Re: BSB67] #596787
01/30/10 11:07 AM
01/30/10 11:07 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Who said it was the BESTest(or very near the top) ? .. not directly .. but it was inferred.
And JUST BECAUSE the RB intake does well ...does not mean the B engine one will also follow-suit.
And you suggest Eddy will make anything(no matter what the performance is) .. just to make money ? WrongO .... Vic is a smarter business-man than that. I have MET and TALKED to Vic ...when I was an NHRA sponsor.
Re: 440 intake manifold [Re: dOoC] #596788
01/30/10 12:13 PM
01/30/10 12:13 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I don't know if this will help the orignal question of fitment but i have the eddy performer on my GTX. It fits fine with stock air cleaner. No hood issues. Performs well on my mild 440. Better then the torker that was on the car. Not sure if it would fit perfet with air grabber set up. I do beleive it is a tad higher then stock intake.
Re: 440 intake manifold [Re: Dougsmopars] #596789
01/30/10 12:39 PM
01/30/10 12:39 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Doesnt mopar performance make an M1 dual plane? I know they did for the smallblock and it looked like an OEM manifold yet made more power than the "Leading Competitors"....(performer) manifold.
Keep old mopars alive.
Re: 440 intake manifold [Re: 2boltmain] #596790
01/30/10 01:08 PM
01/30/10 01:08 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
Sure did open the door on this question. If the clearence is so tight on the air grabber. So the six pack setup being 1 3/4 inches taller than stock clears because of the air cleaner/filter setup?
Re: 440 intake manifold [Re: stateroadhog] #596791
01/30/10 01:29 PM
01/30/10 01:29 PM
Shoreline, Washington
72roadrunnergtx Offline
The N96/Air Grabber air cleaner base used for the six-pack is specifically designed to accommodate the additional height of both the carbs and 6bbl manifold height relative to the under hood components.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 440 intake manifold [Re: dOoC] #596792
01/30/10 01:35 PM
01/30/10 01:35 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't know, who? Your making the claim not me.
No point in arguing opninions on DP4B verses CH4B.
I too have spoken with Vic. Great guy. They make some great products and I am thankful that they continue to contribute to the sport. However, just like every other reputable business man I know, he is in the business to make a profit. If he believed that he could get an ROI better than other initiatives currently underway at Edelbrock, he would do it. If you think otherwise, your kidding yourself.
Re: 440 intake manifold [Re: dOoC] #596793
01/30/10 02:10 PM
01/30/10 02:10 PM
Manitoba, Canada
Manitoba, Canada
Well the DP4B is just the B block version of the CH4B, so yes I am going under the assumption that the flow characteristics between the two is basically the same. I am betting the engineers working for holley used basically the same design for B and RB versions of this intake, rather than starting all over from scratch again.
Nobody is saying the CH4B flows as well as the holley SD, eddy RPM or TM7. In applcations where there is sufficiant head flow to warrant max intake flow, the CH4B would not be at the top of the heap. But when you need a stock height intake, it's a good choice IMO.
Why didn't they repop this intake? Well if you take the CH4B, rotate the carb pad 180*, change it to a spreadbore and add a thermoquad choke well, visusally at least you have an edelbrock performer intake. Maybe they tweaked the intake design a little and gave it a different name so they could keep selling new intakes instead of having everyone going after cheap used pieces? Hey it's possible...
Re: 440 intake manifold [Re: stateroadhog] #596794
01/30/10 03:34 PM
01/30/10 03:34 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
Re: 440 intake manifold [Re: DaytonaTurbo] #596795
01/30/10 06:10 PM
01/30/10 06:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would agree with this. Maybe they tweaked the intake and got the best out of it with more modern tech. Then called it the Performer RPM which is a better intake but a bit taller. I guess they figured the RPM would sell and why compete against their own newer intake by selling an older design. Thats just what I think they may have done but really dont know. Ron
Page 2 of 3 1 2 3
