OEM SB 308 Head Flow #596555
01/28/10 02:01 PM
01/28/10 02:01 PM
On the south side of Nowhere
S/ST 3040 Offline OP
I've been looking at these things on the shelf for a while,
wondering what they would flow straight off an engine.
OEM valve job with .100" wide seat. I touched up the 45º
on both valves, just enough to clean them.
.................. IN .................................... EX
.100"_______54.0______________________51.8
.200"______108.3______________________99.7
.300"______163.6_____________________135.5
.400"______194.9_____________________152.3
.500"______207.9_____________________157.2
.550"______207.9_____________________157.2
.600"______B/UP______________________*****
***** guide prevented further lift
Intake port backs up above .550" lift.
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596556
01/28/10 02:04 PM
01/28/10 02:04 PM
OEM 1.88" and 1.60" valves
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596557
01/28/10 02:12 PM
01/28/10 02:12 PM
Tulip valve required between 24.5º and 25º back cut to blend into back angle.
Results of using this valve with no other modifications.
.100"_______61.4
.200"______122.6
.300"______173.4
.400"______196.8
.500"______196.8
.550"______196.8
.600"______196.8
.650"______196.8
Again, I ran out of travel but, obviously saturated.
I guess "stalled" is a better term since, it can flow more than 196.8
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596558
01/28/10 02:16 PM
01/28/10 02:16 PM
Pushrod pinch is .750" wide.
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596559
01/28/10 02:19 PM
01/28/10 02:19 PM
......because
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596560
01/28/10 02:24 PM
01/28/10 02:24 PM
OEM intake seat.
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596561
01/28/10 03:31 PM
01/28/10 03:31 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The low lift flow went up by almost 14% with the back cut.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: OEM SB 308 Head Flow [Re: Rapid340] #596562
01/28/10 03:46 PM
01/28/10 03:46 PM
Anybody familiar with OEM valves may remember the
pronounced ridge on the back side.
Re: OEM SB 308 Head Flow [Re: Rapid340] #596563
01/28/10 03:47 PM
01/28/10 03:47 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
your peak flow with the back cut is about what I would've expected OOTB, ~195...
2017 Grand Cherokee Overland
Re: OEM SB 308 Head Flow [Re: patrick] #596564
01/28/10 03:57 PM
01/28/10 03:57 PM
Yeah, I'm not seeing anything special here.
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596565
01/28/10 04:01 PM
01/28/10 04:01 PM
They appear to be about as "Swirl" inducing as any 587-up LA head I've ever seen.
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596566
01/28/10 04:28 PM
01/28/10 04:28 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Now what's your plan? I'd be curious to know how many hours (=$$) it would take to get them to flow around 240-ish, or equal to a RHS/X or EQ Magnum head...
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596567
01/28/10 04:30 PM
01/28/10 04:30 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
......because
I was talking with Larry Meaux a couple of years ago(great guy) and he had quite a few that came without the pushrod hole machined for obvious reasons.
Re: OEM SB 308 Head Flow [Re: cudadoug] #596568
01/28/10 04:37 PM
01/28/10 04:37 PM
No plan, as of now.
I was just breaking up the day from my regular grinding duties.
240 CFM would be easy.
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596569
01/28/10 05:44 PM
01/28/10 05:44 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The swirl is produced by the runner. (and the pronounced pushrod pinch). I have never seen anything unique about the 308 chamber either.
Re: OEM SB 308 Head Flow [Re: Rapid340] #596570
01/28/10 05:50 PM
01/28/10 05:50 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I got 278 CFM out of the intake by starting with the MP template kit (no longer available) and adding some other extras like raising the roof. I'm sure Vic could produce a lot better low lift numbers than I but the pushrod pinch limits peak flow.
Re: OEM SB 308 Head Flow [Re: cudadoug] #596571
01/28/10 07:27 PM
01/28/10 07:27 PM
wappinger falls new york
Jimi_Vignogna Offline
i did a set of 1.88 intake valve heads for a 318 volare stocker and with out porting and cover up got them to flow 234 @ .450 , the best 308 s/s head i ever did was 272 cfm at .700
Re: OEM SB 308 Head Flow [Re: S/ST 3040] #596572
01/28/10 09:52 PM
01/28/10 09:52 PM
Petersburg, Va
Darrell Offline
Darrell  Offline
Petersburg, Va
But the exhause radius is so much better, I have a set on my 450 lift 318 with 8.2 CR and would love to try them on a higher CR 340 or 360.
Re: OEM SB 308 Head Flow [Re: Darrell] #596573
01/28/10 09:58 PM
01/28/10 09:58 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
The 308's are pre-magnum right? What years would I need to look for?
Re: OEM SB 308 Head Flow [Re: DusterKrazy] #596574
01/28/10 10:01 PM
01/28/10 10:01 PM
Correct. 88-91 360 only.
