Re: OEM SB 308 Head Flow
[Re: S/ST 3040]
#596557
01/28/10 03:12 PM
01/28/10 03:12 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Tulip valve required between 24.5º and 25º back cut to blend into back angle.
Results of using this valve with no other modifications.
.100"_______61.4 .200"______122.6 .300"______173.4 .400"______196.8 .500"______196.8 .550"______196.8 .600"______196.8 .650"______196.8
Again, I ran out of travel but, obviously saturated.
I guess "stalled" is a better term since, it can flow more than 196.8
[Re: S/ST 3040]
#596561
01/28/10 04:31 PM
01/28/10 04:31 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
The low lift flow went up by almost 14% with the back cut.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#596563
01/28/10 04:47 PM
01/28/10 04:47 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
your peak flow with the back cut is about what I would've expected OOTB, ~195...
[Re: S/ST 3040]
#596567
01/28/10 05:30 PM
01/28/10 05:30 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
......because
I was talking with Larry Meaux a couple of years ago(great guy) and he had quite a few that came without the pushrod hole machined for obvious reasons.
[Re: cudadoug]
#596568
01/28/10 05:37 PM
01/28/10 05:37 PM
S/ST 3040
Now what's your plan? I'd be curious to know how many hours (=$$) it would take to get them to flow around 240-ish, or equal to a RHS/X or EQ Magnum head...
No plan, as of now.
I was just breaking up the day from my regular grinding duties.
240 CFM would be easy.
[Re: cudadoug]
#596571
01/28/10 08:27 PM
01/28/10 08:27 PM
Posts: 428 wappinger falls new york
Jimi_Vignogna
i did a set of 1.88 intake valve heads for a 318 volare stocker and with out porting and cover up got them to flow 234 @ .450 , the best 308 s/s head i ever did was 272 cfm at .700
[Re: S/ST 3040]
#596572
01/28/10 10:52 PM
01/28/10 10:52 PM
Posts: 1,634 Petersburg, Va
Darrell
Petersburg, Va
They appear to be about as "Swirl" inducing as any 587-up LA head I've ever seen.
But the exhause radius is so much better, I have a set on my 450 lift 318 with 8.2 CR and would love to try them on a higher CR 340 or 360.
