1964 plymouth vin # #596533
01/28/10 02:37 PM
01/28/10 02:37 PM
OHIO,CIRCLEVILLE
68DARTTURBO Offline OP
OHIO,CIRCLEVILLE
On the vin # on a 64 savoy where could find some vin #s that would help find out what the car is such as motor or trans
Re: 1964 plymouth vin # [Re: 68DARTTURBO] #596534
01/28/10 09:11 PM
01/28/10 09:11 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
A 64 VIN will tell you if it was a 6 or 8 cyl but nothing more beyond that. If the VIN starts with a "2" then it was a /6 car. If it starts with a "3", then it was a V8 car.
Is the fender tag still present? Have you looked for and found a broadcast sheet?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
